Old 09-09-2015, 09:22 PM   #1
popsmodela
Default Rewire headlights
Is the arrangement/order/location of the three wires in the headlight plugs important or will any arrangement work ?
popsmodela is offline   Reply With Quote
Old 09-09-2015, 09:28 PM   #2
Pete
Pete's Avatar
Default Re: Rewire headlights
The wires have to be on the right pins.
Old 09-09-2015, 11:03 PM   #3
700rpm
700rpm's Avatar
Your plugs might have letter indicators on them to tell you which color wire goes where.
Ray Horton, Portland, OR
Old 09-09-2015, 11:57 PM   #4
Brentwood Bob
Bratton's catolog, page 80, has a diagram. Green/brite, red/dim, yellow/parking.
Brentwood Bob is online now   Reply With Quote
Old 09-10-2015, 05:02 AM   #5
RonC
RonC's Avatar
Yes, high beam, low beam, parking light. The high is the lower bulb filament
RonC is offline   Reply With Quote
Old 09-10-2015, 06:12 AM   #6
Del in NE Ohio
Del in NE Ohio's Avatar
The plug will only insert into the headlight one way. Look at the plug. They repo's I have used are color coded. Y for yellow, R for red, and G for green. If you orient your wires accordingly, you should be good to go.
Del in NE Ohio is offline   Reply With Quote
