Old 11-30-2020, 03:24 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default My temp Gauge goes to hot Now?
I have a heat gun with Laser and the engine is not hot 160 so the Temperature sender is no good. I think it repo which I heard is junk. Have any of you Fellow's had any trouble with them? Might put a Oil Pressure and Temp gauge bottom of the dash.
Old Redneck is offline   Reply With Quote
Old 11-30-2020, 04:23 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: My temp Gauge goes to hot Now?
Some of the 'new replacement' style Temperature sensors may operate backwards for some reason???
And some that are labeled as NOS for '57 may actually be a later version that does the same.
You can't win some days
Old 11-30-2020, 08:33 PM   #3
55blacktie
I intend to supplement my original 55 Tbird gauges with quality electric oil pressure, water temperature, and voltage gauges, mounted under the dash. After spending thousands to rebuild the engine, I don't want to leave it to chance.
55blacktie is offline   Reply With Quote
Old 11-30-2020, 08:58 PM   #4
paul2748
paul2748's Avatar
Because of incompatible sender vs gauge problem, CASCO (and I imagine other suppliers) have a matched gauge and sender set. I hear it works good.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-01-2020, 02:05 AM   #5
KULTULZ
KULTULZ's Avatar
Thumbs up Re: My temp Gauge goes to hot Now?
Originally Posted by 55blacktie View Post
i intend to supplement my original 55 tbird gauges with quality electric oil pressure, water temperature, and voltage gauges, mounted under the dash.
After spending thousands to rebuild the engine, i don't want to leave it to chance.
Amen!
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
