10-14-2018, 10:40 PM | #21 | |
Re: Understanding the oil filter canister ..
On the question and opinions on the presence of restrictors, I seem to remember that the inlet restrictors were located at different places in different times by different manufacturers, the only constant being that the restrictors would always be on the inlet side, with little or no restriction on the outlet side. Should some misguided person remove an inlet restrictor at some point in history, that engine would then suffer from very low oil pressure for the relatively short remainder of its existence.
Alan |
10-14-2018, 10:59 PM | #22 |
Alan,
Thanks, so you are saying it is good to have to suck the oil out and wipe out any residue and particals, which just draining it would not do. I have not yet completely hooked my oil filter up. I have a '36 with a 8BA motor in it and some previous owner had completely removed the oil filter. I have since found another one and have it in place. But I also want to re-hook up the original dash oil pressure gauge. I have the two-outlet restrictor but I think it needs to be mounted down low on the back of the block, which at this time I cannot get to. I seem to remember seeing someone had hooked the restrictor up to the side of the oil filter and then screwed the electrical '36 style oil pressure sending unit into it, again at the top of the filter housing and it just looked sloppy to me. I hope when I convert the brakes to hydraulic and have the wooden floor panels removed, that I can then get to the proper mounting place down on the back of the motor. Steve |
10-15-2018, 12:04 AM | #23 |
Steve, yes, just suck it out with a turkey baster or a small hand pump, any one of a hundred different varieties available from many sources. I wouldn't stress about residual particles on the bottom, they're not going anywhere.
You can remove/replace the sending unit on the block from under the hood with a cheap open end wrench bent into a U shape. Some guys even get fancy with welding up a home made wrench for the job. You say you have "the two outlet restrictor"... I presume you mean you have the T fitting that accepts the oil filter line as well as the oil pressure sender. Just confirm that a restrictor is present somewhere in the inlet side, consisting of a plug of some sort with a single hole about 1/16" diameter.
Alan |
10-15-2018, 12:05 AM | #24 |
My 1940 canister has a drain plug just up from the bottom while my later 8BA canister does not have this drain plug. Even with the plug you have to soak up some off the bottom.
10-15-2018, 08:08 AM | #25 | |
10-15-2018, 08:28 AM | #26 |
10-15-2018, 08:29 AM | #27 |
10-15-2018, 03:27 PM | #28 |
I have a '46 Merc that has a threaded boss welded on for a drain plug in the bottom of the canister. It's pretty handy. But I've used the turkey baster for years... works fine
