Old 09-13-2019, 10:02 PM   #1
jstrez5
Default starting problems
39 flathead wont start the motor turns over but wont start i am not getting any spark to my plug wires where would be the first place to start looking the motor just quit a few back firings also i am getting gas to the carb any help would be appreciated thanks jim
jstrez5 is offline   Reply With Quote
Old 09-14-2019, 01:05 AM   #2
cajunfirehawk
cajunfirehawk's Avatar
Default Re: starting problems
a) have a firewall resistor, if so ck that
b) bad coil, ck that
c) wiring to one of the above, ck that
d) dizzy issues, ck that
Has to be one of those for no spark, IMHO
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 09-14-2019, 06:24 AM   #3
chap52
chap52's Avatar
If you have looked down the carb and pumped the throttle and saw gas spraying your good there.
Now You say that there is no spark at the plugs. Start backtracking from there. Remove the center coil wire from the coil a bit, is there spark there? If so it's in the distributor. Keep backtracking until you locate the last "hot" spot that has juice. Don't start ordering parts because "it may be" this or that. Unless you want to be like the rest of us and have a tote full of extra parts.
Keep us posted, and "Enjoy the adventure"... Chap
chap52 is offline   Reply With Quote
Old 09-14-2019, 11:42 AM   #4
G.M.
Send your coil and a few condensers to Skip Haney. He will rebuild
your coil and hot test the condensers. [email protected] G.M.
www.fordcollector.com
Old 09-15-2019, 04:53 PM   #5
jstrez5
Had a spare resistor so I replaced that. Spent a little more time with the spark plugs and I am getting a spark, but it is very inconsistent. After a couple tries at starting the engine sounds like it is about to start, but never fires up. Anyone else have any ideas?
Old 09-15-2019, 05:43 PM   #6
JSeery
JSeery's Avatar
You can try bypassing the resistor and see how it works. Take the wire that comes from the ignition switch and move it from the ignition side of the resistor to the coil side of the resistor (connected on on top the coil wire already there). You can run it for a short period of time to test it.
Old 09-16-2019, 09:46 PM   #7
jstrez5
The problem was a bad condenser thanks guys for all your help till next time ? Jim s.
Old 09-17-2019, 06:38 PM   #8
Gumpy
Gumpy's Avatar
Its always a good idea to replace the points also..
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 09-17-2019, 07:07 PM   #9
tubman
tubman's Avatar
He's right of course. In the course of going bad, the condenser usually loses capacitance, which leads to material transfer between the points. If you find you have a bad condenser, at least check the points and dress them with a points file if there is any deposition.
Old 09-17-2019, 07:16 PM   #10
Blastfromthepast
I agree with that. I had a similar problem and the points were dirty and the point gap was way off. I cleaned the points, adjusted them correctly and there was spark. Check your point gap.
Blastfromthepast is offline   Reply With Quote
Old 09-21-2019, 08:15 PM   #11
jstrez5
i check the points and they are clean and set right thanks again. jim s.
