09-26-2021, 08:55 AM | #1 |
35 Drums on 36 spindles
Hello fellow Ford nuts. I need your help with this one.
I want to use the 35 ford 5-1/2 bolt pattern wheels on my 36 instead of the wide 5s and keep the mechanical brakes. So my question to ya'll is.....Will 1935 Ford front brake drums fit on 1936 spindles? I understand that the spindles are the same with the exception of the 35 snouts being 5-5/8 and the 36 being 5-3/8.....Do i need to make any mods to make this set-up work? If so, what mods? Thanks for any help.. John in central Texas "Its never too late to have a happy childhood" |
09-26-2021, 09:23 AM | #2 |
Re: 35 Drums on 36 spindles
There have been some recent posts on this very same subject that cover your questions pretty well. Do a search and see if you can find them, if not, someone here will find them for you.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-26-2021 at 09:53 AM. |
09-26-2021, 10:12 AM | #3 |
thanks for your reply.
none of the previous posts really answer my question. they assume i want to run 35 wires on my 36. thats not what i was looking for. |
09-26-2021, 10:42 AM | #4 |
09-26-2021, 11:18 AM | #5 | |
Also, another word of caution, if you mount '40-'48, 5 on 5-1/2 wheels on '35 hub/drum assemblies without removing the nubs/projections, it will bend the center of those wheels when the lug nuts are drawn down tight. Don't ask me how I know this since I don't want to embarrass an old friend
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-26-2021 at 11:35 AM. |
09-26-2021, 01:37 PM | #6 |
09-26-2021, 08:33 PM | #7 |
good '35 drums are desireable as is, please do not modify them. Newc
09-27-2021, 06:26 AM | #8 |
There has been a pair on EBAY for weeks and no one has bought them.Here is the link.
https://www.ebay.com/itm/11390821233...EAAOSwAN1dkivd |
09-27-2021, 07:05 AM | #9 |
Being a machinist & thinking about it, as the ‘35 drums are desirable as Newc says & you don’t want to alter them I would think you could buy a set of the support rings & modify them with relief in the positions where the nubs on the ‘35 drums are?
Nomad |
09-27-2021, 11:25 AM | #10 | |
Here's a post from 2017 that gives details on the support rings mentioned above... https://www.fordbarn.com/forum/showt...+support+rings
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-28-2021 at 02:19 PM. |
09-27-2021, 02:27 PM | #11 |
Just a. Thought.
Nomad |
