Old 03-16-2021, 09:33 PM   #1
Clem Clement
Clem Clement's Avatar
Default Soldering bullet wire ends to socket
I'm reading the some of us solder their wire bullet end to the socket to guarantee a secure and good fit.
I have to replace the dash light dimmer switch. The bullet ends on my replacement wire harness will not fit in the socket. Solder does not stick to to the socket sides which I filed clean
It is common practice to solder these connections. Does it pass during judging?
TIA
Old 03-16-2021, 09:43 PM   #2
35fordtn
35fordtn's Avatar
Default Re: Soldering bullet wire ends to socket
Are you using flux?
Old 03-17-2021, 10:07 AM   #3
Clem Clement
Flux in the solder. I'll try again
Old 03-17-2021, 12:35 PM   #4
35fordtn
35fordtn's Avatar
I have always used seperate liquid flux and silver solder.
Old 03-17-2021, 01:22 PM   #5
19Fordy
19Fordy's Avatar
Clem, I just took these photos of my 40 dash light dimmer switch that may help you.
It was in the car when I bought the car in 1963. I think it's original to the car. Redundant photos may shed a little more light.
Old 03-17-2021, 05:27 PM   #6
Lawson Cox
Lawson Cox's Avatar
I don't think that's the kind of wire ends he is talking about. He says bullet ends. FWIW. Solder will not work if the bullets are chrome plated.
Old 03-17-2021, 06:11 PM   #7
slowforty
slowforty's Avatar
I gave up trying to do anything with my dimmer switch .It worked all right but i had to keep adjusting it as it would not stay in one position. I just put both wires together and the dash lights are on the brightest(?) setting. And I dont have to lay on the seat anymore
slowforty is offline   Reply With Quote
Old 03-17-2021, 07:22 PM   #8
paul2748
paul2748's Avatar
What is the fitting problems with the bullet ends? Too small? The Ford bullets are bigger that the ones commercially available today. The Ford bullets are available
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-17-2021, 08:13 PM   #9
rotorwrench
rotorwrench's Avatar
The originals were tinned copper but the modern ones can be machined brass or press formed from brass sheet. If they are new and they can't be crimped, ie. machined brass, then the wire should be tinned with solder before an attempt to solder it to the brass. I would use 63/37 tin/lead solder. Lead free will work but a bit more flux is needed. It takes too much heat for silver or hard solder. As others mentioned, check the fit before soldering and make sure they will work.
Old 03-18-2021, 11:13 AM   #10
glennpm
glennpm's Avatar
I used these bullets for some connectors on my 32. They are .176" diameter or a tad less than 4.5mm. They work perfectly with the stock connectors.
The blue plastic can be removed with a razor blade. They can be soldered but I'm a proponent of crimping only.
Glenn
Old 03-18-2021, 09:43 PM   #11
Clem Clement
I'm working an idea
Old 03-19-2021, 12:18 PM   #12
32phil
If you solder the connection BEFORE you crimp the concern is if the joint heats up for whatever reason the solder may soften/melt and then the crimp will no longer be tight.
I always crimp first creating a solid mechanical connection then I solder.
Even if it overheats and all the solder melts away the joint will still be there mechanically.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 03-19-2021, 01:18 PM   #13
19Fordy
19Fordy's Avatar
32phil: Good point.
Old 03-19-2021, 06:16 PM   #14
rotorwrench
I don't worry about the solder melting on any connections that I have to solder. If the solder melts then there is resistance due to a bad or shorted wire, a loose connection, or too small a wire gauge for the current draw in the circuit.
Old 03-19-2021, 09:10 PM   #15
Clem Clement
I thought I had a neat way to do this. I took a paper clip and wrapped one end of it around the receiver on the switch. (The wire is about an inch below the dash rail. I wrapped the other end on the cloth wire above the bullet nose and set it in the receiver. that gave me both hands for soldering. Oh, before that it tinned the receiver on the work bench. I'm thinking but no luck with the soldering iron making the solder run to the bullet. Rosen was every where. The switch if too close to the dash to use heat.
Old 03-20-2021, 02:35 AM   #16
ford38v8
ford38v8's Avatar
Clem, don’t give up, soldering is not rocket science, but it does require proper methods, tools & materials like any other skill. There is a soldering iron or torch, along with the correct solder and flux for every job, and instruction material for every student. First lesson: Don’t expect first timer success on any project you haven’t practiced for. One small tip you might use on your particular application is to use a heat sink to prevent collateral damage.
Alan
Old 03-20-2021, 08:28 AM   #17
russcc
This a bit off topic, but I was wondering if there was a good way to get what appears to be copper bullet connectors that hook the '40 headlight switch pigtails to the wiring harness apart without damaging the wire and insulation.
Old 04-05-2021, 01:36 AM   #18
Clem Clement
The short harness wires and the closeness to the the painted dash make soldering a challenge. I'm letting the project rest a bit and then will get after it again. Thanks
Old 04-05-2021, 06:12 AM   #19
glennpm
glennpm's Avatar
Just crimp it, pull on it to make sure its tight and you're good to go. No need for the solder.
Glenn
Old 04-05-2021, 11:15 PM   #20
Clem Clement
The bullet end does not fit in the connector. Thanks
