Old 10-16-2018, 03:01 PM   #1
Peter Onorato
Default 1953 Mainline Turn ignal wiring
Please, can somebody identify the 6 wires coming out of the bottom of the steering column? Using an ohm meter I think I've Id'ed some of them:
Blu-Flasher/Pwr
Grn/Ong tracer-LR blinker
Ong/Blu tracer-RR blinker
Grn/Yel tracer-LF Blinker
Yel (not sure really faded)/Blu tracer-RF Blinker
Grn-??
Peter Onorato is offline   Reply With Quote
Old 10-16-2018, 03:45 PM   #2
JSeery
JSeery's Avatar
Default Re: 1953 Mainline Turn ignal wiring
Have you looked at the wiring diagram?
Green is to the brake light switch.
White/Blue is RF Blinker & Dash Indicator
Green/Blue is LF Blinker & Dash Indicator
Green/Orange is LR Blinker
Orange/Blue is RR Blinker
Blue is to the Flasher Canister
Old 10-16-2018, 03:55 PM   #3
MMB
Last three "should" be: Orange- LF blinker
White/Blu tracer- RF blinker
Solid Green- from stop light switch
MMB is offline   Reply With Quote
Old 10-16-2018, 04:16 PM   #4
41ford1
41ford1's Avatar
Here is a wiring diagram that was included in a NOS directional switch kit I installed in a 53 sedan delivery.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 10-16-2018, 04:24 PM   #5
41ford1
41ford1's Avatar
Here is a jpeg of the above diagram.
Old 10-16-2018, 07:02 PM   #6
Peter Onorato
Outstanding! Thanks so much.
Pete
Old 10-16-2018, 08:39 PM   #7
41ford1
41ford1's Avatar
The tail light label on the diagram should read brake light. If you need it I have the NOS rear harness that came with the kit. My car was prewired for an after market switch. Send me a PM if you need it.
Old 10-16-2018, 11:30 PM   #8
Paul Bennett
That sidewise diagram possessed me so I opened up my photoshop. At least 2 wires have wrong colors but I went according to the sidewise diag.
Feed me corrections and I'll edit them in. One this tho -- what is a 'BLINKER'?
Paul Bennett is offline   Reply With Quote
Old 10-17-2018, 06:47 AM   #9
51 MERC-CT
51 MERC-CT's Avatar
What is a 'BLINKER'???
It's a light that flashes on and off as opposed to one that stays lit.
Old 10-17-2018, 08:11 AM   #10
JSeery
JSeery's Avatar
Just a common term used for a flashing light. In many cases it is referring to the brake filament in the tail light bulb when it is wired to "blink" on and off as a turn signal indicator or a similar filament on the front. Really a slang term I believe, I would consider it a verb rather than a noun.
