Old 09-26-2017, 02:15 PM   #1
Kentmac
Default 29 Roadster top removal/ replace
I am going to have my 29 roadster repainted and cannot figure out how to remove the top. It appears to be stapled around the back and I am concerned that if I remove all the staples, I will never get it back nice and tight. Any suggestions or information.
Kentmac is offline   Reply With Quote
Old 09-26-2017, 02:34 PM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: 29 Roadster top removal/ replace
The only ones that were tacked too the wood in the back were the OCPU.. do you have a
Roadster Pick-Up?
d.j. moordigian is offline   Reply With Quote
Old 09-26-2017, 06:17 PM   #3
Kentmac
It is not a pickup, it is a roadster. I cannot see how to disconnect the rear of the top. Could it possibly be bolted down, do you know of any diagrams of the roadster tops that could be viewed?
Old 09-26-2017, 07:08 PM   #4
wrndln
The top on a 28/29 roadster originally was removable unlike a phaeton or OCPU that were not. The wood beltrail has twist clips that holds the top on at the bottom. I am posting a picture of a fine point 29 roadster that shows part of the bottom of the top with the correct clips. The front clip is to install the side curtains.
It appears that someone didn't install your top the correct way. I agree with you without some "salvage edge" left on the car it would be very difficult to reinstall the top to the beltrail.
Rusty Nelson
Old 09-26-2017, 07:15 PM   #5
Vern
Vern's Avatar
The top on my '28 roadster is attached to the wood rail at the top of the seat with push type cinch fasteners. They screw into the wood, and the top has grommets that the fasteners go thru to hold it in place.
Vern is offline   Reply With Quote
Old 09-26-2017, 08:13 PM   #6
700rpm
700rpm's Avatar
Take it to an automotive upholsery shop that works on tops and see if they have a suggestion.
Ray Horton, Portland, OR
Old 09-27-2017, 10:48 AM   #7
Kentmac
Here are pics of my roadster top. The seatback fabric comes up and over the top of the seat and apparently is stapled to a wooden block which is bolted to the body. The top is apparently atttached to the back edge of the block with staples as well with a section of trim over the staples... looks like I paint with top on or get a new top. Thanks for all the comments
Old 09-27-2017, 10:49 AM   #8
Kentmac
Sorry about that, looks like they are all upside down
Old 09-27-2017, 11:48 AM   #9
d.j. moordigian
Attachment 332097
Attachment 332098
Attachment 332099
The seat fabric attaches too the wood strip, which is correct. The top uses
snaps, like Rusty shows in his photo..#4..
Old 09-27-2017, 11:50 AM   #10
CHuDWah
CHuDWah's Avatar
Rusty Nelson
A bit off-topic but can the OCPU top be folded down like a roadster or phaeton? Somewhere, I got the idea it cannot but I'm not sure.
CHuDWah is offline   Reply With Quote
Old 09-27-2017, 12:43 PM   #11
wrndln
An OCPU top cannot be folded down. There are some people that have modified or made top irons that will fold down. I don't know how well they work - probably not real well.
Rusty Nelson
Old 09-27-2017, 05:03 PM   #12
pooch
pooch's Avatar
Yup, hidem is not used there at back of roof to body.
Check inside hidem , is it nailed or stapled?
If the roof materail is still pliable, you should be able to carefully pull out fasteners and get back in same place.
The roof is only tight when it is connected to windscreen posts.
When it is off posts, it is loose at back and will be easy to fit back on.
It will be a nightmare for the painter with the roof still there.
pooch is offline   Reply With Quote
Old 09-28-2017, 04:14 AM   #13
Dollar Bill
Dollar Bill's Avatar
Kentmac, welcome to the Ford Barn!
OP States: "looks like I paint with top on or get a new top."
I'm with pooch. If you're dropping the coin for a new paint job, you (or your painter) won't be happy with the job if the top is left in place.
In for a penny, in for a pound
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
