04-19-2018, 07:55 PM | #1 |
early v 8 detailed rebuilding manuel
i am wanting to know what is the best rebuilding motor book out there for someone new to early ford v8s. I have worked and restored model A's from my teens, there are a very large and detailed books on A's.When I look for early fords there is all kinds about hot rodding them'. what i am looking for is a step by step floor mat. Thanks for any help
04-19-2018, 08:17 PM | #2 |
Re: early v 8 detailed rebuilding manuel
I would look at a couple:
Ron Bishop's book Rebuilding the Famous Ford Flathead: https://www.google.com/search?q=rebu...0MS3CPbl0ugDM: And the more illustrated Ford Flathead Engines - How to Rebuild and Modify: https://www.themotorbookstore.com/ho...QaAuNWEALw_wcB
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
04-19-2018, 08:19 PM | #3 |
There are several. Here are a few I like. JWL & Ol Ron are Barn contributors.
04-19-2018, 08:26 PM | #4 |
H&H flatheads has a very detailed book, Ron Holleran has good info on rebuilding early motors and setting up floating rod bearings. John Lawson has great info as well.
I don’t think there is a “best” book, because they all have good info, and I use several at once. Like reloading manuals, I don’t rely on just one. |
04-19-2018, 10:37 PM | #5 |
I have one by a George McNichol that I particularly like. If you're like the rest of us, you'll end up with all of 'em by the time you're done.
04-20-2018, 06:44 AM | #6 |
John |
04-22-2018, 07:18 PM | #7 |
Thanks for all the help.
04-23-2018, 01:48 PM | #8 |
The best all around manual I have seen is the Canadian Ford book. It is available from C&G as item V-222. It has 475 pages with specs and illustrations. Ford did not publish a comprehensive shop manual in the US, preferring to use "bulletins". You can see the wide range of manuals on their web page www.cgfordparts.com
04-23-2018, 02:54 PM | #9 |
That Canadian Ford book was based on a military tech manual and was likely the best overall for the 59A & earlier types back to around 1939 to 42 for original stock restoration. In the 8BA era, the 49 thru 51 Lincoln Mercury overhaul manual is about the best for stone stock Ford & Mercury engines.
Most of the later books cover building in more power from mild to wild. All of it is good info though. You can never have too much information. |
04-23-2018, 07:43 PM | #10 |
I didn't know about the Canadian book - just ordered it, figured there is always something more to have for a reference.
Thanks! D |
04-23-2018, 08:10 PM | #11 |
There is also the book of instructions Ford provided to their authorized rebuild shops.
