Old 09-13-2019, 07:53 PM   #1
fordy6
Default Master cylinder bleeding
I re-plumbed all my brake feeds on my stock '46 coupe and also replaced all wheel cylinders and master cylinder. Do I have to bench bleed my master cylinder? I've never done that before and would like to know the procedure. A video would be very helpful. All the videos I could find where later model cars with dual reservoirs.
Thanks, Mike
[email protected]
fordy6 is offline   Reply With Quote
Old 09-13-2019, 08:13 PM   #2
paul2748
paul2748's Avatar
Default Re: Master cylinder bleeding
A single chamber master usually does not require a bench bleeding.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-13-2019, 08:16 PM   #3
FortyNiner
FortyNiner's Avatar
I would recommend bench bleeding the MC. Check out this video at about the 11 minute mark: https://m.youtube.com/watch?v=tOCkFYhTskQ
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 09-13-2019, 08:23 PM   #4
drolston
drolston's Avatar
By bleeding the brakes cylinders, you also bleed any air from the Master Cylinder. Attach a clear tube from the nipple on the bleed valve down to the catch jar. Crack open the bleeder valve (maybe half a turn); have your helper push the pedal to about 2" from the floor; stop there, tighten the bleeder, then let the pedal back up to the top. Repeat until you see no bubbles coming out through the bleeder tube. The first wheel will take many pumps. Start with the furthest wheel, the right rear, then the left rear, then the right front, then the left front. If you ever let the fluid in the master cylinder get to the bottom in that process, you pretty much have to start over. That should give you a hard pedal. If you still have a spongy pedal, you missed a bubble somewhere.
Old 09-13-2019, 10:00 PM   #5
Vics Stuff
Vics Stuff's Avatar
Pre bleeding will speed up the brake bleeding process.
Vic
Vics Stuff is offline   Reply With Quote
Old 09-14-2019, 05:19 AM   #6
flatford8
flatford8's Avatar
I changed the master in my ‘50 this past spring and I bled it first. I didn’t have to do anymore bleeding and have a full pedal..... I’d recommend bench bleeding the master....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-14-2019, 06:48 AM   #7
fordy6
Thanks fortyniner, video was helpful
Mike
