Old 04-22-2019, 07:40 AM   #1
Sod Buster
Sod Buster's Avatar
Default jamming nine snakes in a bean can.
Holy crap, I hope I never have to do this again, it was a wrestling match.
I thought I had it whipped at this point, yeah right.
It looked like it could explode at any minute.
It was a relief to get the distributor bail thrown over it before someone lost an eye.
Sod Buster is offline   Reply With Quote
Old 04-22-2019, 08:30 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: jamming nine snakes in a bean can.
If you de burr the inside of the outer cap and radius the path the wires take, the wires will slide in there easily. The plastic casting has square corners that makes getting the wires past difficult. There is plenty of material in there to do this. A little silicone spay helps too.
Old 04-22-2019, 08:31 AM   #3
RKS.PA
RKS.PA's Avatar
Great job, Sod!!! See you are doing it as "original" with the correct brown wires and the rabbit ear distributor. I'm think about this because I'm currently using the crab with earlier wires.....the brown ones weren't available at the time I redid the ignition.
Also, really like the way you've dressed up your block and engine compartment....very nice!!
RKS.PA is offline   Reply With Quote
Old 04-22-2019, 08:33 AM   #4
RKS.PA
RKS.PA's Avatar
P.S. also really like the "Wichita" correct air cleaner!
Old 04-22-2019, 08:53 AM   #5
Sod Buster
Sod Buster's Avatar
I did take a Drimel to it, the silicone sounds like it would of helped.
Old 04-22-2019, 08:57 AM   #6
Sod Buster
Sod Buster's Avatar
Keeping the crud off my Beehive, lol.
Old 04-22-2019, 08:59 AM   #7
tubman
tubman's Avatar
The final result sure looks good! It had to be worth the effort.
Old 04-22-2019, 09:09 AM   #8
34pickup
34pickup's Avatar
Thats the main reason I changed to a crab style cap.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-22-2019, 12:04 PM   #9
rotorwrench
rotorwrench's Avatar
Some folks like the cotton braid covered 7mm ignition leads better and some prefer the Packard 440 GM type 7mm ignition leads but I don't know if any of them fit any better in the rabbit ear cap. I like the crab style too. There were a number of years where the crab type cap was all the parts stores had.
Old 04-22-2019, 02:58 PM   #10
larry butcher
Want more fun? Rewire a flathead Lincoln V12, from plugs, conduits,into caps w/ coil
wires and O.D. shunt wires!
larry butcher is offline   Reply With Quote
Old 04-22-2019, 04:48 PM   #11
Sod Buster
Sod Buster's Avatar
Four more wires, what could go wrong, lol.
Old 04-22-2019, 09:28 PM   #12
Tinker
Tinker's Avatar
If it's your last Flathead you won't have to do it again. I didn't think it was all that hard.
Looks great! Interesting theme you got's going.
Old 04-22-2019, 11:08 PM   #13
51woodie
51woodie's Avatar
When I did my '46, I found that getting all those wires in the correct orientation to get the outer cap on is a challenge for sure. It lookes by your pictures, that you had the conduits mounted on the engine, then fed the wires through. I put mine together on the bench, then mounted on the engine. It made fishing the wire through fairly easy. I also took my multimeter and double checked to make sure I had the wires going to the correct plugs before I installed the parts. Didn't want to take it apart again!
51woodie is offline   Reply With Quote
Old 04-23-2019, 12:59 PM   #14
Krylon32
There'e a reason Ford went to a top mount distributor in 49.
Krylon32 is offline   Reply With Quote
Old 04-23-2019, 04:54 PM   #15
Sod Buster
Sod Buster's Avatar
Kind of a pain, but it is the cleanest plug wire routing of any vehicle I have ever owned, they sure aren't going anywhere.
Old 04-23-2019, 05:00 PM   #16
Sod Buster
Sod Buster's Avatar
Yes The conduits were on, that part really wasn't that bad, I stuck a cotter pin threw each one as I fished them out so they would not pull back through.
Old 04-23-2019, 05:12 PM   #17
35fordtn
35fordtn's Avatar
I recently went through this as well. Learned each time i have done a set, not to let anger prevail ; as each time that happens I break the outer cap and have to start back over. It’s indeed a quite attractive setup when done.
One of those tasks that makes you wonder how they did such on a assembly line. Those poor guys had to have had some very sore fingers every night.
35fordtn is offline   Reply With Quote
Old 04-23-2019, 05:29 PM   #18
Sod Buster
Sod Buster's Avatar
The car itself is some what interesting, different for sure, the interior was customized in 1968, the car sat for years tarped in a garage, the quirkiness of the car is what made me pull the trigger. I am not sure if the car is great fit for this site, but here are a few pics of it. Hide your eyes if your faint of heart.
Old 04-23-2019, 07:15 PM   #19
MGG
MGG's Avatar
[QUOTE=35fordtn;1750102
I have also wondered the same thing whenever I perform this task.
My guess is that in another part of the plant, they had people at stations, or tables, assembling the wires, conduits and caps into units. They could have as many of these people as was necessary to be able to have the assembled units arrive at the assembly line when it was time to put them on the car. Don't know for sure, but it seems to me to be reasonable. Speed up the line? Add more people putting the units together.
MGG is offline   Reply With Quote
Old 04-23-2019, 07:36 PM   #20
JSeery
JSeery's Avatar
It is amazing how easy these assembly task appear when you watch videos of the assembly lines!
