07-03-2016, 06:24 PM | #1 |
Mrg part date for transmission case?
Hi All,
I'm in the middle of rebuilding the transmission and I can't seem to get the bearing for the main shaft to fit into the housing correctly - it sticks out too far by about 1/16th of an inch so that when I try to mount the bearing retainer the two aren't flush. The housing I'm using is not original to the car. It doesn't have a groove for the snap ring in the main shaft bearing hole. I'm wondering if I have a housing from pre-Sept'29. If so, do I just skip the snap ring outright? Is there another part I should be using instead? I'm hoping there's a way to date the housing itself to tell if I should be using the snap ring or not. Thanks in advance for your help! |
07-03-2016, 07:56 PM | #2 |
Re: Mrg part date for transmission case?
There 5 styles of transmission cases. There are cases that have a machined bearing stop for the front and rear ball bearings. These were the first cases used in model A's. The later style cases use a snap ring in the machined grooves. If I remember correctly, the bearings do stick out a little bit, but the bearing retainers should fit using the required gaskets. I suppose the bearings you have could be a little too thick. I saw that on a rearend I was helping rebuild a few months ago. The bearings are the same for all the cases.
Rusty Nelson |
07-03-2016, 08:10 PM | #3 |
Thread Tools | |
Display Modes | |
