05-03-2019, 02:53 PM | #1 |
Engine swap 46-48 flathead into a 37
What is involved in swapping a newer 46-48 flathead into a 37?
My 37 runs good but smokes and burns oil something terrible. It is the original 21 stud 221 with a cornhusker T5 conversion kit. I may have access to an engine out of a 46-48 pulled to do a street rod conversion from my neighbor. Wondering what is involved in the way of different parts needed etc |
05-03-2019, 04:25 PM | #2 |
Re: Engine swap 46-48 flathead into a 37
The should be a direct replacement.
05-03-2019, 04:28 PM | #3 |
bellhousing? the 37 has integral bellhousing. Should clutch be the same?
05-03-2019, 04:46 PM | #4 | |
The 46-48 has an "integral" bellhousing as well. Clutch should be no problem as well. The separate bellhousing was introduced in '49....
05-03-2019, 05:09 PM | #5 |
Bod drake makes a hose set to fit the later eng into the early car
Lawrie |
05-03-2019, 05:14 PM | #6 |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
05-06-2019, 10:24 PM | #7 |
Would the headers, generator, fan, water pumps, carb that I have for 37 21 stud all work on 46-48 flathead?
05-07-2019, 05:59 AM | #8 |
You can get an adapter to run the early distributor on the later engine I think
05-07-2019, 08:41 AM | #9 |
