Old 01-10-2020, 12:27 PM   #1
adileo
adileo's Avatar
Default 52 F1 wipers
Hi guys
I’m trying get wipers to work. I am not using stock switch. I took hot 6 volt lead and attached it to top left then top right on motor terminal (see pic- sorry sideways left) the motor ran on top left for 20 seconds and died. Never ran on top right. I am assuming motor is no good. You agree?
File Type: jpeg 6B092487-347F-490F-A8B9-FF804F72E342.jpeg (21.0 KB, 15 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 01-10-2020, 12:38 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 52 F1 wipers
It's hard to read and figure out even when enhanced.
Didn't realize that F-1's had electric wipers.
Old 01-10-2020, 03:20 PM   #3
adileo
adileo's Avatar
Figured it out. Both sides need to be hot.
Thanks
Andy
1952 F1
Old 01-11-2020, 10:25 AM   #4
Scotty's 52 F3
Scotty's 52 F3's Avatar
I found out the motor is VERY sensitive to how tight the case bolts are when I had cleaned and lubed mine. I finally slowly tightened them while I had it running in my vise. Also lightly tapping it with a soft mallet.
Maybe just how mine is? Try it if yours seems to bind up at all.
I also tightened the mounting screws in the dash while it was running for the same reason.
Scotty's 52 F3 is offline   Reply With Quote
