02-01-2020, 04:38 PM | #1 |
Is this junk
Got the crank cleaned up and noticed some damage around the hole on the rod journal. Quick measurement says rods have been turned 10 and mains 20. No cracks in the block so that's a plus. The guy I got the crank from will give me another one but I need to disassemble it.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
02-01-2020, 05:27 PM | #2 |
Re: Is this junk
Clean it up, chamfer the damage around the oil hole, and you will be good to go as long as there is not a crack somewhere.
02-01-2020, 05:39 PM | #3 |
Re: Is this junk
Is is a Ford or Merc. crank? Ford cranks are a dime a dozen, so it may pay to look for a better one, but I agree with Russ. Clean up the hole, machine it and run it if you'd like.
A guy at Hershey has a huge spot. Something around 8 spots. He had a tent that covered six of them. At each pole, he had a Ford crank tied to the rope. I asked him about his interesting choice of wind weights and he replied, "What else am I going to do with them?" I got a good laugh from that. |
02-01-2020, 06:09 PM | #4 |
Re: Is this junk
Also depends what it will clean up at. Looks like it might take a good bit of grinding.
02-01-2020, 06:22 PM | #5 |
Re: Is this junk
Sorry it is a merc crank. This is going to be somewhat stock just trying to do it the right way.
02-01-2020, 06:36 PM | #6 |
Re: Is this junk
02-01-2020, 07:00 PM | #7 |
Re: Is this junk
I wouldn't worry about the oil feed bores as much as whether it will clean up at .030" under. You can chamfer the oil ports a good bit and not hurt function at all.
02-01-2020, 09:52 PM | #8 |
Re: Is this junk
You can just chamfer the oil hole - heck, we do that with all our racing cranks anyway. Obviously it will need a regrind, but going to 20 on the rods should not be a big deal and getting to 30 on the mains - can still get bearings, so you should be good to go.
If it was mine, I'd remove the knock-in soft plugs on the rod throws and tap them for a threaded Allen plug - is the best way to go (don't have to worry about soft plugs getting blown out). Best of luck! |
02-02-2020, 12:29 AM | #9 |
Re: Is this junk
Shoe shine it some with fine emory paper and measure it
02-02-2020, 03:17 AM | #10 |
Re: Is this junk
My bet is that the damage was done before the crank was reground...so it has be run and worked as is...
02-02-2020, 08:03 AM | #11 |
Re: Is this junk
It could also be welded by the crank grinder and reground. Not junk Below is a photo of a drive shaft being welded on a crankshaft welder.
02-02-2020, 03:58 PM | #12 |
Re: Is this junk
Too pitted for my liking. Especially in the seal area. Going to ask for another. Thanks for the help.
02-02-2020, 04:23 PM | #13 |
Re: Is this junk
I wonder how that happened. I tore a Merc. Engine apart that sat outside for years and the only part of the engine that wasn't rusted was the crank. Needed only turned .010. The rest including the block was junk.
02-02-2020, 06:40 PM | #14 |
Re: Is this junk
Don't trash it. Someone, sometime will be able to use it, since it's a Merc.
02-02-2020, 07:07 PM | #15 |
Re: Is this junk
It might still work for floaters if a person wanted a 4" crank in an older engine.
02-02-2020, 07:19 PM | #16 |
Re: Is this junk
Looks like a porous casting. I'll take it and run floaters. It would make a nice warmed up 99T.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
02-02-2020, 10:42 PM | #17 | |
Re: Is this junk
New project is to bust open the next candidate. Bless the Flathead Gods that you will have impressive horsepower.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
