08-15-2019, 09:57 PM | #1 |
Flex fuel line with one way valve
I'm hearing a flex fuel line from the fuel pump available with a one way valve.
On mine the fuel runs back to the tanks after shut down |
08-15-2019, 10:17 PM | #2 |
Re: Flex fuel line with one way valve
Check valves in the pump should prevent that. or you have a leak close to the pump.
Robert Shewman P.O. box 163, Kimberton PA 19442 More info here on the check valve flexhose... https://www.fordbarn.com/forum/showt...se+check+valve |
08-17-2019, 09:33 AM | #3 | |
That's simply a "band aid" approach to patching vs. a correct repair. Do yourself a favor and send your pump to Charlie. He'll rebuild it PROPERLY and return it quickly to you.
08-18-2019, 12:29 PM | #4 |
fuel pump is 6 months old. Thanks
08-18-2019, 02:01 PM | #5 |
Was it rebuilt? If so, by whom? When? Is it a reproduction?
