Old 08-09-2019, 09:50 PM   #1
zoegrant
zoegrant's Avatar
Default Brake light switch for 55 ford
my brake light switch on my 55 sedan is not sensitive enough to go on when gently applying the brakes. The brake lights come on if I come to a hard stop.
Can they be adjusted in any way ?
Also, is the switch under the dash ?
zoegrant is offline   Reply With Quote
Old 08-09-2019, 10:09 PM   #2
miker98038
miker98038's Avatar
Default Re: Brake light switch for 55 ford
It’s on the brake lines and hydraulic from line pressure. I know some use the switch off a Harley as it activates at low pressure. I can’t tell you which one. I put a mechanical under the dash, made a bracket to work off the brake arm.
miker98038 is offline   Reply With Quote
Old 08-09-2019, 10:10 PM   #3
51504bat
51504bat's Avatar
Same problem with the one in my '39 pick up. Switch is hydraulic, mine is behind the m/c. I've heard a switch from a Harley m/c solves the problem. Simple bolt in replacement. Or you can adapt a mechanical switch. I believe mid 50's p/u's used them. Other threads on the HAMB and I think the flathead section here on the barn.
Old 08-10-2019, 01:01 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: Brake light switch for 55 ford
This little switch is the answer to any vehicle that has an old out of date low pressure brake light switch. This new switch made by CPP activates your brake lights on at 45psi, not 95psi like the originals, allowing for a faster signal to your taillights and allowing a lot more time for the car behind you to react. While the original switch was rated for drum brakes, the new switch was made with disc brakes in mind! Everyone who looks at this auction needs to hit the buy it now as this is a must have item! Remember, everything wears out eventually, so update that old crusty outdated switch to a new upgraded unit. You won't believe the difference.
SOURCE - https://www.ebay.com/itm/CHEVY-FORD-...-/280876618864
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 08-10-2019, 12:33 PM   #5
19Fordy
19Fordy's Avatar
Read all this.
https://www.fordbarn.com/forum/showt...e+light+switch
Old 08-10-2019, 03:02 PM   #6
zoegrant
zoegrant's Avatar
I am going to change my brake light switch on my 55 sedan with a low pressure one I bought on Ebay.
When I remove the old switch which is screwed into a brass junction block on the back of the master cylinder will the old switch removal require I bleed the brakes after replacement with a new switch ?
Old 08-10-2019, 07:58 PM   #7
paul2748
paul2748's Avatar
No - you don't have to bleed the brakes. Done this a number of times w/o bleeding and never had a problem. Have the new switch in your hand near the old switch as you remove it.
I made up a bracket attached to the pedal support and installed a mechanical switch. Instant brake lights just touching the pedal. I have sort of a how to if your interested. Similar to the one sold by the TBird suppliers.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-11-2019, 12:19 PM   #8
zoegrant
zoegrant's Avatar
Thanks for the info on whether I need to bleed the brakes. If the new switch I have on order is not sensitive enough I would appreciate a how to on the pedal actuated switch.....I had one from a T-bird vendor on my 56 bird and loved it...thanks
Old 08-11-2019, 11:04 PM   #9
Daves55Sedan
Daves55Sedan's Avatar
The OEM replacement switches are not DOT 5 silicone brake fluid compatible. But the repro parts suppliers sell a "low-pressure" brake light switch that is silicone brake fluid compatible. I put one of those on my '55 Sedan many years ago. My '55 Courier has a Harley brake light switch. Either one is proper pipe thread for factory brake fitting at the nose of your master cylinder.
Either way you go, you will need to snip off the factory bullet connectors at the end of your wires and use the pigtail set that comes with the new switch.
Old 08-13-2019, 11:13 AM   #10
bobss396
bobss396's Avatar
This is the one I use, I save it in my eBay favorites in case I need another one. Definitely low pressure. And I changed it and didn't bleed the brakes.
https://www.ebay.com/itm/Chevy-Ford-...53.m1438.l9372
bobss396 is offline   Reply With Quote
Old 08-13-2019, 11:15 AM   #11
zoegrant
zoegrant's Avatar
Hi Bob...that looks like the one I just ordered on Ebay….Thanks for the picture.
Old 08-13-2019, 11:20 AM   #12
bobss396
bobss396's Avatar
Glad to help. It trips at 45 PSI. I got one with a CPPP proportioning valve that leaked immediately. Grabbed one at NAPA that took high pressure to trip. I'm happy with the one I got, should pick up another one just in case.
Old 08-13-2019, 01:49 PM   #13
51504bat
51504bat's Avatar
Check out the link. Seller is Gearhead Enterprises. Lots of bad reviews/comments over on the HAMB and other places. Caveat Emptor.
