Old 08-11-2019, 10:14 PM   #1
slumlord44
Default Source for voltage regulator for '57 T Bird
Replaced regulator with new Americian made one last September and it died yesterday. This is about the 3rd one in as many years. Any suggestions for a good one or is there and electronic replacement available?
slumlord44 is offline   Reply With Quote
Old 08-12-2019, 10:53 AM   #2
Daddio
Daddio's Avatar
Default Re: Source for voltage regulator for '57 T Bird
This seems to be pointing to another problem that's destroying the VR. I wish I was more experienced in charging systems to help.
Perhaps a known good used VR. I've never had to replace the one in my '56 Tbird.
Daddio is offline   Reply With Quote
Old 08-12-2019, 06:11 PM   #3
rotorwrench
rotorwrench's Avatar
A lot of the new restoration stuff is crap. If you have an old time automotive electrical shop near you, take an old original VR in and have them check it out. If you have a possible generator problem, you may need to think about taking it in too. If the car has an electrical system with deteriorated wiring or insulation, there can be intermittent shorts which can damage both the voltage regulator and the generator. Make certain your whole electrical system is up to snuff.
Old 08-12-2019, 09:04 PM   #4
dmsfrr
dmsfrr's Avatar
Originally Posted by Daddio View Post
This seems to be pointing to another problem that's destroying the VR. ...
Originally Posted by rotorwrench View Post
... If the car has an electrical system with deteriorated wiring or insulation, there can be intermittent shorts which can damage both the voltage regulator and the generator. Make certain your whole electrical system is up to snuff.
slumlord44,
Here's a 'borrowed' post to check out the long list of things that can cause voltage regulator damage.
At first glance I prefer the first link in the post... sort of a long read but VERY informative.
Among other things;
the ground connections between the block, body & battery can easily be overlooked, in a '57 Bird
https://www.fordbarn.com/forum/showp...0&postcount=14
Old 08-12-2019, 11:11 PM   #5
slumlord44
The generator was recently rebuilt by an old time rebuilder and checked again when I had regularot problems. Still looking for a better one or an electronic replacement.
Old 08-13-2019, 11:22 AM   #6
bobss396
bobss396's Avatar
Any VR I have ever seen has had a ground strap close to where it mounts, worth a look anyway. Usually to the radiator wall from one of the VR screw holes.
bobss396 is offline   Reply With Quote
