11-08-2019, 09:37 AM | #1 |
PCV process
Probably a dumb question but somebody said even dumber is not asking I had an unrelated issue and no good PCV valve at hand so connected PCV hose direct to vacuum from crankcase and did what I needed. Test drove the vehicle all seemed fine. Couple days later I got a new PCV valve & put it in. The question is why do u need the PCV valve on the crankcase to vacuum tube? Its a one way valve. Is it so not to steal too much vacuum from engine? Don’t beat my ignorance up to bad
Nomad |
11-08-2019, 10:01 AM | #2 |
Re: PCV process
A PCV system is basically a vacuum leak. The PCV valve is to attempt to control that leak under different engine vacuum conditions.
11-08-2019, 10:11 AM | #3 |
Re: PCV process
The most important function of the PCV valve is to close off any flame path in the event of a carburetor backfire that may detonate the crankcase.
11-08-2019, 10:17 AM | #4 |
Re: PCV process
Backfire.
I had a 317 ohv Lincoln backfire one time from a timing issue. Blew the oil fill cap off and blew out both valve covers. The 2 studs managed to keep the covers on the motor but you could slip your fingers in passed the gaskets. |
11-08-2019, 12:47 PM | #5 |
Re: PCV process
Got it! Thx. Hind sight 2020 & makes sense now that I learnt better��
Nomad |
11-08-2019, 01:35 PM | #6 |
Re: PCV process
11-08-2019, 07:48 PM | #7 |
Re: PCV process
you must be running very rich , other wise you'd be running like crap , if at all , with unported vacuum .
11-08-2019, 08:52 PM | #8 | |
Re: PCV process
Hope you are not talking about a labyrinth rear seal motor here ?
If yes you may have a mess in the rear of your crankcase . Quote:
11-09-2019, 05:54 AM | #9 |
Re: PCV process
When is the last time you have seen an 8BA Flathead Ford equipped with a Labyrinth rear seal?
11-09-2019, 09:15 AM | #10 | |
Re: PCV process
Agreed on the 8BA not having a labyrinth seal .
That said please point out where this post says what type motor is being discussed ? Quote:
11-09-2019, 10:09 AM | #11 |
Re: PCV process
One of the main purposes of the PCV, ie; the valve therein, is to close under acceleration so there is enough vacuum to operate the vacuum advance in the distributor.
Bill.... 36 5 win cpe |
11-09-2019, 04:36 PM | #12 |
Re: PCV process
I have an electronic dist w no vac advance. Which is why it doesn’t notice the vac loss I guess. It is an 8BA, sorry should’ve said in 1st post.
Nomad |
