08-18-2019, 01:39 PM | #1 |
‘42-‘46 pickup cabs & nose question!
Pictorially the ‘42-‘46 1/2 ton PU truck cabs & fenders look similar to the 1 ton, but I’m guessing theyre different between the 1/2 ton PU & the 1 ton trucks & not interchangeable?
Nomad |
08-18-2019, 02:23 PM | #2 |
Re: ‘42-‘46 pickup cabs & nose question!
The big truck front fenders have a bigger opening to accommodate the larger diameter tires.
08-18-2019, 02:48 PM | #3 |
they are deceivingly wider, especially at the rear/running board area
08-19-2019, 09:45 AM | #4 |
So no go for interchangeability?
Nomad |
08-19-2019, 11:14 AM | #5 |
Not for the fenders, but the cabs are pretty much the same. I am not 100% sure so I was waiting for someone else to reply, but I think the cabs are all similar.
08-19-2019, 12:19 PM | #6 |
Nomad |
08-19-2019, 01:28 PM | #7 |
I believe "Mart" is correct. There may also be different placement of the gas tank as well.
08-19-2019, 09:23 PM | #8 |
if the 1 ton nose is in good shape , get them they are also hard to find and would also make some good trade pieces. I personally would use them. I have a 41 3/4 stake bed and it has the same "big" truck front end and looks good.
08-21-2019, 12:43 PM | #9 |
That does look good Allen! Is the cab the same as the 1/2 ton pickup? I’ve got the ‘42 - ‘46 1/2 ton cab, frame, bed & rear fenders, which is what I want the front end 4?
Nomad |
08-21-2019, 01:07 PM | #10 |
"41 3/4 stake bed and it has the same "big" truck front end and looks good."
08-22-2019, 09:52 AM | #11 |
On the 42-46 trucks the hood and grille on the large truck are the same as pickup but the fenders have a larger opening even though they will bolt on the 1/2 ton.
08-28-2019, 09:26 PM | #12 |
Good info deuce5wndw
Thx
Nomad |
