06-04-2019, 10:03 AM | #1 |
61 Galaxie steering question
Is there a difference between a power and manual steering box on a 1961 Galaxie?
06-04-2019, 11:59 AM | #2 |
Re: 61 Galaxie steering question
same
06-04-2019, 01:31 PM | #3 |
Many of the early type systems had a hydraulic actuator as part of the steering linkage. In the early 60s they started to change over to steering boxes with internal actuators to simplify things. Many older systems had standard steering gearboxes same as non power cars. Adding power steering required no change of the gearbox but just the addition of the pump and an actuator.
06-05-2019, 09:07 PM | #4 |
06-05-2019, 11:29 PM | #5 | |
There were also two boxes used (61/ ), the FORD and the SAGINAW. The SAGINAW can be quickly recognized as it used a two-piece steering shaft with coupler (rag joint) as opposed to the FORD design box using a one piece steering shaft and worm. EDIT - CORRECTION- One piece steering shaft w recirculating ball design ...
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-06-2019 at 06:27 AM. |
06-06-2019, 12:57 PM | #6 |
