04-11-2018, 03:37 PM | #1 |
Inside Door Handle Spring '41
After careful study, I concluded that the only way to replace the broken door handle spring was to remove the brace by bending the tabs that hold it to the triangular mounting plate. Of course the critical tab (the one that catches the spring) broke off.
The piece is more like pot metal than steel; pretty sure it can not be repaired by welding. I can not find the inside door handle mechanism on Ebay or any of the reproduction parts sites. First; Is there a source for the inside door handle mechanism. Left/drivers door on a business coupe (narrow door) versus Sedan Coupe (wide door). Second; is there any way in H*** to replace that spring without taking the mechanism apart? Make my day and say "no". |
04-11-2018, 08:04 PM | #2 |
Re: Inside Door Handle Spring '41
I also need that info.
04-11-2018, 09:42 PM | #3 |
Warm up the tab first. Be gentle. Then weld it when it breaks.
Bruce
Works good Lasts long time |
04-12-2018, 03:45 AM | #4 |
It is weldable if necessary but there are mechanisms available that can be used by swapping the pull rod to fit the application.
Such as this.--------- https://www.ebay.com/itm/41-42-46-47...VaoHwu&vxp=mtr
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 04-12-2018 at 03:58 AM. |
04-12-2018, 07:13 AM | #5 |
If you grind the tabs off, those will come apart and go together easily; then tack weld the stubs of the tabs at assembly.
04-12-2018, 09:11 AM | #6 |
04-12-2018, 06:03 PM | #7 |
I did the '40 coupe exterior door handle by bending the tabs and taking the mechanism apart. Tough job, but it came out ok. Good idea, welding the tabs, a lot easier than trying to bend them back again.
04-12-2018, 07:21 PM | #8 |
My eBay skills are better than my welding skills, and I found one for the wide door '41 - '48, for which I can swap the pull rod to match my narrow door. Then I will try to weld the original and, if successful, give it to the next person who shows up on this board with a broken left front door handle spring.
