11-16-2017, 10:21 AM | #1 |
cutout disassembly
How does the cutout come apart? I took out all the screws, but it appears the outer case and inner assembly are soldered or tacked together. I purchased the diode, but have never seen one apart.
11-16-2017, 10:34 AM | #2 |
Re: cutout disassembly
Tacked. File the tacks. And tap edges to work top off.
11-16-2017, 10:46 AM | #3 |
You have to break the solder joints.
11-16-2017, 12:11 PM | #4 |
Either work a small chisel or screwdriver between the cover and bottom plate or grind off the area where the welds are.
11-16-2017, 01:07 PM | #5 |
That is not a Model A cutout so why not put your money and your time into a Model A cutout. The one you show in the photo will fit and work OK, but is the later series as used on the Ford V8.
11-16-2017, 07:11 PM | #6 |
11-19-2017, 01:39 AM | #7 |
I have done a few of these original cut outs, It is not hard to break the spot welds with a small chisel just be careful. I think Tom Wesenberg has a holding fixture for these. Easy to make. Do a search on it.
