01-16-2022, 04:38 PM | #1 |
Cheap 21 inch tires
Where can I buy the cheap 21 inch Model A tires that are made in Vietnam? I bought a set a few years ago. They were Lucas I think and they cost about $100 each with free shipping. There was a Universal tire that was also about that price. I cannot find where I purchased them. Thanks for the help.
01-16-2022, 05:45 PM | #2 |
Re: Cheap 21 inch tires
Good afternoon...You can go on line and purchase directly from Lucas...They will ship to you.. 800-952-4333. Ernie in Arizona
01-16-2022, 05:58 PM | #3 |
Good luck on the 100 and free shipping
aint gonna happen.................. |
01-16-2022, 07:45 PM | #4 |
Call Steve at Bert’s
He sells black wall European tires for About $120 Each and with free shipping? Check there AD in the MARC an MAFCA newsletter. |
01-16-2022, 09:28 PM | #5 |
Joop- those tires appear to be of much better quality then the other inexpensive ones. I hope that price still stands. I was quoted the 120 a tire last April.
01-17-2022, 10:54 AM | #6 |
01-17-2022, 11:47 AM | #7 |
European Classic Tyres $119 at Performance Plus Tires, free shipping.
https://www.performanceplustire.com/...ge-bias-ply-2/ Last edited by Y-Blockhead; 01-17-2022 at 11:58 AM. |
01-17-2022, 12:31 PM | #8 |
Call Steve - best Model A friend you could have!!
01-17-2022, 12:58 PM | #9 |
Y- need to add a 25. boxing chg and also tax, if your state requires it.
01-17-2022, 01:29 PM | #10 |
01-17-2022, 01:35 PM | #11 |
Bought a set from Snyder a while back. I have had good luck with these tires.
01-17-2022, 02:08 PM | #12 |
I went on to order to see if there was shipping- yes they hit you with a boxing chg on the site you mention..........
01-17-2022, 02:10 PM | #13 |
best to get the Restorer and look for the ad for European tires- they have the dealers listed with phone numbers- no tax, no boxing chg and no extras........
as Earl Sheib used to say no UPS no extras!!!!!!!! |
01-17-2022, 03:56 PM | #14 |
01-18-2022, 12:23 PM | #15 |
Berts has these tires:
From their website: "Remember: We only charge actual shipping costs - NO EXTRA HANDLING FEES!!" Note that means no boxing fees! UPS and FedEx ship four tires taped together ... no box required. Last edited by Benson; 01-18-2022 at 12:30 PM. |
01-18-2022, 01:13 PM | #16 |
Benson- no shipping fees at all from the dealers listed in Restorer..........
just the tire chg |
01-18-2022, 01:27 PM | #17 |
4.40/4.50-21" Black and White wall The new European Classic 4.40/4.50-21" tyre with 75-mm whitewall is produced in Europe and designed to offer classic whitewall styling with the classic pattern from the old days. An ideal choice for classic antique cars. The tyre has a modern tubeless construction to avoid flat spots but it is also designed to be used with tubes. The tyre is the only E-marked tyre in this size, and it is 100% road-legal for use in Europe and DOT-marked for the US market. To avoid the classic familiar staining problem, the tyres are produced in 100% stainless black rubber, which minimises browning/yellowing of the white rubber. E-marked DOT marked Tred width4"10 cm Section width4.8"12 cm Inflated diameter30.8"77 cm White wall2 3/4"70 mm Speed index130 km/hM Load index1168lbs@32 Psi86 - 545 kg Weight17.5 Pound8 kg TypeTube type but tubeless design COMPETITOR COMPARISON European ClassicFirestoneB.F. GoodrichGoodyearLucas E-markedNoNoNoNo Text in White wallOnly Black wall Ply rating44442 Non Staining (no risk for Brown White wall)NoNoNoNo Tubeless contructionYesNoNoNoNo Flat spots when storring the Car for winter - with correct air pressure I have no stake in this, but the european classics seem to be far better rated then the others listed.......................... NoMaybeMaybeMaybeYes |
