Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 07-31-2020, 05:18 PM   #1
ldreeg
ldreeg's Avatar
Default 1949-1948 Mercury
City: MCKINNEY
State: TX
Bought all the parts.
Need left (driver) side front apron (splash shield) for 1946-1948 Mercury. Also 2 short stainless steel trim pieces that go between the left and right side aprons above and below the crank hole cover.
Thank you.
ldreeg is offline   Reply With Quote
Old 08-04-2020, 03:20 PM   #2
ldreeg
ldreeg's Avatar
Default Re: 1949-1948 Mercury
btt
Old 08-09-2020, 03:43 PM   #3
ldreeg
ldreeg's Avatar
Purchased lower crank hole cover trim (thank you Ford Barn). Still need the upper one and the splash apron.
Old 08-20-2020, 11:16 AM   #4
ldreeg
ldreeg's Avatar
Found the upper crank hole cover trim. Still need the driver splash apron.
