Old 01-09-2020, 03:53 PM   #1
xelhan
Default Radial tires for AA Trucks
Coker Tire offer the Excelsior Stahl Sport Radial Tire in 600R20
Are there any other radial tire in this size?
xelhan is offline   Reply With Quote
Old 01-09-2020, 07:40 PM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: Radial tires for AA Trucks
This is the first I ever herd on radial tires for the AA's How much do they want for them
Gunmetal blue2 is offline   Reply With Quote
Old 01-09-2020, 08:07 PM   #3
David R.
Aren’t those designed for race cars?
David R. is offline   Reply With Quote
Old 01-09-2020, 09:34 PM   #4
holdover
Would the radials work with tubes??
holdover is offline   Reply With Quote
Old 01-10-2020, 05:31 AM   #5
Bruce of MN
Bruce of MN's Avatar
Doesn't look like it: https://www.cokertire.com/excelsior-...rt-radial.html
Old 01-10-2020, 08:11 AM   #6
77Birdman
Coker says they are inspired by vintage competition and early race cars, but if that's the same size needed for an AA why not? Around $350 ea.
77Birdman is offline   Reply With Quote
Old 01-10-2020, 10:03 AM   #7
xelhan
They are tube type and of perfect size, but $340 is on the expensive side - $2,653 for 7 tires with tubes. That's why I was wondering if there was any alternatives. I have 600R16's Excelsior Stahl Sport Radials on my 34' Tudor and I love them.
Old 01-10-2020, 03:03 PM   #8
1931 flamingo
1931 flamingo's Avatar
Are you a purist?? If not , go with modern tires. A LOT LESS expensive.
Paul in CT
Old 01-10-2020, 05:13 PM   #9
xelhan
What brand would that be?
Old 01-11-2020, 05:03 AM   #10
xelhan
Paul in CT
Any suggestions
Old 01-11-2020, 10:44 AM   #11
1931 flamingo
Have no idea in Sweden. Ck with a local tire store.
Paul
Old 01-11-2020, 02:45 PM   #12
xelhan
Paul
Paul, since you said " go with modern tires", I was asking for a tire brand and hopefully a specific type, not a Swedish retailer
Old 01-11-2020, 11:59 PM   #13
Bill Cilker
Bill Cilker's Avatar
If you have a 1930-31 AA with dual rear tires, Radials will probably rub between the tires where they expand at the bottom from the load.
Ford had problems with the bias ply tires rubbing during production.
Bill
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is online now   Reply With Quote
Old 01-12-2020, 10:05 AM   #14
xelhan
Originally Posted by Bill Cilker View Post
If you have a 1930-31 AA with dual rear tires, Radials will probably rub between the tires where they expand put at the bottom from the load.
Bill
I have to check on that - Thanks
Old 01-13-2020, 01:07 PM   #15
xelhan
Bill
You are right Bill!
The bias tires do contact at the bottom, but they don't seem to rubb any. I believe they only touch gently with no rubbing since there are no motion between them. I can not see any wear or scuffing marks. What kind of problem was it?
Old 01-13-2020, 01:46 PM   #16
Bob C
Ford addressed the problem of the tires rubbing with new wheels. See the
Service Bulletins page 528 January 1931.
Bob
Old 01-13-2020, 04:46 PM   #17
xelhan
Bob
Bob, where do you find those Service Bulletins?
Old 01-13-2020, 05:48 PM   #18
Bob C
All the vendors sell them. https://www.brattons.com/paperback-m...bulletins.html
Old 01-14-2020, 03:22 AM   #19
xelhan
Thanks, have just ordered
Old 01-14-2020, 01:45 PM   #20
xelhan
Bob
I received this information from Coker:
Chris, If current, stiff sidewall bias tires are touching, then it is likely the Excelsiors will do so as well. That shouldn’t be a problem as you note they cannot rotate freely of each other, but it may be something to at least keep an eye on.
Michael Howard
Web Sales Manager
I did order the Service Bulletins but it will take several weeks to get them. I would appreciate if someone will publish Service Bulletins page 528 dated January 1931
