Old 12-04-2018, 04:17 PM   #21
37 Coupe
37 Coupe's Avatar
Default Re: Water pump to buy?
Too many pumps too many choices.Only thing I have decided on is Bratton;oe Snyders and one has 2 year warranty other is 1 year >Why go away from both great service.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 12-05-2018, 12:50 PM   #22
Purdy Swoft
Purdy Swoft's Avatar
I agree that a person can get by for a long time with an original pump .The original will require adjustment of the packing nut and greasing from time to time . replacement of the packing will be a part of the maintainance when needed .The only leakless pump that I bought didn't last very long . The leakless pump had a seal that could be seen on the front of the packing nut . I buy the parts and build my own leakless water pumps . Mine usually last 15 years or more but end up costing about as much as buying a leakless pump . No water pump will be leak free forever
Old 11-27-2019, 06:42 PM   #23
gdmn852
gdmn852's Avatar
1980 MGB still rear wheel drive with four cylinders and still had wing windows and kingpins!!!
gdmn852 is offline   Reply With Quote
Old 11-28-2019, 03:04 AM   #24
TerryH
TerryH's Avatar
Per Tom Endy’s advice I bought a Jim Rupert water pump about 14 years ago, and it has about 14,000 miles on it now, with nary a leak.
TerryH is offline   Reply With Quote
Old 11-28-2019, 05:05 AM   #25
john charlton
john charlton's Avatar
In England the Pinto was made here at Fords Dagenham plant by the million .They went up to 2300 cc . They were a "non interference" engine so no damage when the cambelt failed The junkyards were full of them but now long gone , They were fitted to vans,Capri coupes and Cortina sedans
John in Suffolk County England and Happy Thanksgiving to you all .
john charlton is offline   Reply With Quote
Old 11-28-2019, 12:15 PM   #26
rocket1
carbon and ceramic seals are no magic bullet,worked on dishwashers for decades that had them,replaced hundreds,they will go in time.I would stick with the stock pump,simple and lasts and lasts!
rocket1 is offline   Reply With Quote
