Old 05-11-2013, 04:11 PM   #1
MichaelSchwarzer
MichaelSchwarzer's Avatar
Default French Ford Model A Town Sedan
Dear Model A enthusiasts,
since 2007 I follow your page and discussions and i took very many good hints and advise from this forum.
I am located in southern Germany (and I am German) and I am restoring a true barn find of a French 1930 Briggs Town Sedan. We startet in 2006 an try to finish in 2015.
The car was assembled around April 1930 in Asniere, near Paris in France and went through a rough history until ist was finally parked around 1961. In the meanwhile it detiorated into a remarkable wreck.
Please have a look on my restoration projekt at www.fordmodela.com.
I am very thankful that you made through your diskussions this projekt possible in detail, and want to give back a little to others. And of course get some acknowledgement from the experts!
Looking forward to hearing from you,
Michael
MichaelSchwarzer is offline   Reply With Quote
Old 05-11-2013, 05:44 PM   #2
Reds34
Default Re: French Ford Model A Town Sedan
Looks like a good project. A lot of work ahead of you for sure. Good Luck.
Red
Reds34 is offline   Reply With Quote
Old 05-11-2013, 05:51 PM   #3
Pilotdave
Pilotdave's Avatar
Welcome aboard! You have quite a project ahead of you - thanks for posting pictures. Looking forward to more. Good luck.
Pilotdave is offline   Reply With Quote
Old 05-11-2013, 06:04 PM   #4
Steve Plucker
Michael,
Where at in Germany are you?
I am very, very impressed with your website and craftmanship. Well done.
I will say this however...you just might want to reconsider your restorations of the Right and Left Spindle Arms and the Steering Gear Arm...I say this because I at one time purchased those three from someone who did just what you are doing.
As I was heading North and just as I got into Bend, Oregon, I will never forget the feeling when all of a sudden I had no steering!...The "welded" and or pressed-in ball came off the Steering Gear Arm...needless to say, I about soiled my britches!
If you can, find some good originals where the balls are good. I know this is a chore but I will tell you, you will feel a lot safer by doing it this way.
HOWEVER...if you feel confident in your work...then go for it...just my opinion on those three items!
Pluck
Old 05-11-2013, 06:09 PM   #5
Terry, NJ
Terry, NJ's Avatar
Michael. I don't know what french Town Sedans were like, but in the US, it would not be a Town Sedan. First, no cowl lights. TSes, (Town Sedans) all have Cowl lights. Second, The dash Rail is painted. not wood grained. Third, No fold down arm rest in the center of the rear seat. Fourth, no light (maybe) by the top of the rear window. It is a oval lens with a oval Bezel, not round. I may be wrong about this, due to the difference between french models and US models. The Upholstery looks like green Mohair, a standard for Town Sedans. It's nice example for restoration. Macht Spass!
Terry
Old 05-12-2013, 12:27 AM   #6
MichaelSchwarzer
Steve, thanks for your input and that you have startet a thread about the spindle ball subject.
Here it is not so easy to get useable original arms. But regarding your experience I will try, still "some " time left until the first drive. We are in the south of Germany, roundabout 50km south of Munich close to the alps in Bavaria.
Terry, we diskussed the "Town Sedan" issue a lot over here, as the car did not have cowl lights etc. But obviously it went trough a rough resoration, and the cowl lights were eliminated in exchange for the home made spare tire carrier. There were holes for the lights in the cowl. The entire car had been repainted by hand, also the interior parts as the dash and door/window mouldings. I have attached a picture which shows the brown basecolour, will try to get a better one. Under that black colour, there were some remains of the woodgraining. As the entire back seat was missing, we could not say whether there was a center arm rest or not. In the top wood there were holes for the srcews which attach the domelight carrier in the rear, the light itself missing. So we made a decision: TownSedan. But of course this can be wrong. There are some hints that more than one car are the basis of this one, so no one could say for sure. We tried to organize some information in France. But all documents of the factory were lost in WW2. Do you know whether there isin the US some information about the exported and foreign assembled cars?
Thank you so far. Michael
Old 05-12-2013, 12:40 AM   #7
Steve Plucker
Yes there is...It is contained on FORD's Assembly Record Types. France (Asnieres) alone built 347 Town Sedans in 1930 and a total of all units for Asnieres was 12065.
Hmmmmm...It must be 7:40 AM there?
Pluck
Old 05-12-2013, 01:07 AM   #8
Tudortomnz
Tudortomnz's Avatar
Hi Michael
I like your Model A.. It is a Town Sedan as you said as the cowl lamp holes are there, wood roof framing for rear interior lamp & also the deluxe garnish mouldings under the window frames.
I believe these 1930 Briggs sedans originate at the British Manchester Plant & were made LHD & assembled near Paris at Asnieres. Also you are right about French made parts on it as this was required all over Europe. Typically, French lamps, wiring, interiors etc were used [ probably also tires, glass etc.] but I am no expert on all of this. It appears to have been fitted with the large bore engine as the data plate states A; usually if it was a small bore, it would be stamped AF. It will have a US series engine # [ reserved for British cast Model A engines] and finally, some of these Sedans were fitted with sliding sun roofs & leather interiors, at least for the English market.
Tudortomnz is offline   Reply With Quote
Old 05-12-2013, 05:15 AM   #9
ctlikon0712
ctlikon0712's Avatar
Really? A sun roof for sunny old England !
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-12-2013, 07:49 AM   #10
roccaas
roccaas's Avatar
I read somewhere that headlamps on French cars, at some time past, were required to not have light projected through the front of the headlamp, but only through reflection off of a surface. I believe I've seen some Marchal lamps like this. Truth, or a only a bad recollection??
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 05-12-2013, 08:50 AM   #11
davehc
davehc's Avatar
Terry
I have a 30 Town Sedan with center arm rest , and thought all Town Sedans had the arm rest in the rear . DeAngelis book , "The Ford Model A" also shows it . Just courious .
Dave
davehc is offline   Reply With Quote
Old 05-12-2013, 09:19 AM   #12
Steve Plucker
Dave
David,
You are correct...According to the FORD Body Parts List for August 15, 1930, page 37: the 155-C (Murray) and the 155-D (Briggs) both came with a (Rear Seat Center Arm) Rest Assembly.
The 170-B (Standard and De Luxe Fordor 2-window) also came with the Center Arm Rest.
Pluck
Old 05-12-2013, 09:28 AM   #13
eagle
eagle's Avatar
Its amazing to see the birdcage body wood. It makes me shudder to think I bought my Briggs Fordor without even looking at the wood. I didn't realize they were wood framed. I got lucky, the wood is all original and like new but I would not be up to the project you are doing. You will have a beautiful car when done. The Fordors drive differently than other A's because of the weight/balance of the body on the frame. We love ours. Look forward to watching the progress.
Old 05-12-2013, 12:25 PM   #14
Terry, NJ
Terry, NJ's Avatar
Off Topic, But do you know of a town named "Breitenbach" in Bavaria? One of my Great (?) grandfathers came from there.
Back On topic, From what you are saying, it's looking more and more like a Briggs Town sedan that someone "Customised" . Take a few more pictures of The windows. The area directly over the rear windows, and the wiring in the rear, and the rear interior. The Green mohair panels is a stock item for TSes, so that is another point towards it being a TS. I saw the holes in the cowl and wasn't sure if they were factory or not, especially with that weird mounting bracket (spare tire) sticking out of it. If it's not a TS, I would say it's a 4 dr deluxe.
Terry
Old 05-12-2013, 12:25 PM   #15
Christoph
Christoph's Avatar
Hi Michael
Welcome to the Barn ...
and long distance greetings from Frankfurt
Christoph
Christoph is offline   Reply With Quote
Old 05-12-2013, 12:34 PM   #16
Ken Ehrenhofer
Bonjour, Gutentag,
Do you have to speak French when you are driving a French Model A????LOL
Welcome and if we can be of some help please let us know,
Ken
Ken Ehrenhofer is offline   Reply With Quote
Old 05-12-2013, 01:15 PM   #17
30Ford
I'am heading to Germany in 23 days ...it would be great to see a A
30Ford is offline   Reply With Quote
Old 05-12-2013, 02:54 PM   #18
MichaelSchwarzer
Originally Posted by Tudortomnz View Post
Hi Michael
Tom,
It is the large bore engine, number 278 671. The original roof had been replaced by some sheet metal, so I do not know about a sun roof.I can hardly blieve that for the UK. Thanks, Michael
Old 05-12-2013, 02:54 PM   #19
MichaelSchwarzer
Sorry, I have never heard about that!
Old 05-12-2013, 02:58 PM   #20
MichaelSchwarzer
You are right. As I bought the car I had not a glue that there is a wooden frame. To be honest, I read a lot about Model As only after I bought one. The wood was very bad, as you can see. My brother is a carpenter, and so the project developed into a family project! We have some fun like archeologist must have in determing how the wood could have been shaped originally.
