Old 06-18-2018, 04:57 PM   #1
1930artdeco
1930artdeco's Avatar
Default carb stall
Hi All,
Need some help on this one. I have a Marvel carb on my car that has stalled out on me twice going around a curve. I am thinking that the float valve is sticking in the closed position somehow. After she sits for about a minute she fires right back up.
I have fuel in the throat that I can see and feel. The only thing that I can think of doing is enlarging the brass housing just enough so that the needle has a tad more slop in it and doesn't get cock eye in the housing. Sound reasonable?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-18-2018, 05:16 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: carb stall
MMMM gas cap not venting? Easy enough to check without tearing stuff apart. I'm thinkin you are at the start of crud build up in the cap itself.
Tacoma Bob is offline   Reply With Quote
Old 06-18-2018, 05:32 PM   #3
Dick Steinkamp
Dick Steinkamp's Avatar
Seems like it would stall at times other than going around a corner if the gas cap wasn't venting.
I would think instead of not enough fuel, it may be a case of too much...especially if you can see fuel in the carb throat. In any case, I'd check the float setting and make sure the float bowl needle and seat are working properly.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 06-18-2018, 05:46 PM   #4
dpson
dpson's Avatar
Having just gone through setting the float on a Marvel carb, thanks to other articles here on the forum, the quickest way is to remove the carb, take off the cover and check the float level by using a 1/4 inch drill across the cover to check the distance from the cover to the top of the float (bottom of float when turned upside down). You can also order the fuel level measuring kit from Renner's, be aware the instructions on some of Renner's kits say 1/2 inch from bowl flange to the fuel level, however in speaking with them this should actually be 3/4 inch. They also have gaskets that can be used to adjust the fuel inlet valve height and not have to bend the float.
dpson is offline   Reply With Quote
Old 06-18-2018, 06:47 PM   #5
Herb Concord Ca
Hi Mike before you modify anything, I have a few used Marvel float needles for you to try.
Herb Concord Ca is offline   Reply With Quote
Old 06-24-2018, 11:49 AM   #6
DHZIEMAN
Originally Posted by 1930artdeco View Post
Hi All,
Mike
Gotta know more about the cause! What you describe as the car stalling, is definitely around gas flow, but, you stated you let the car sit and then it will start up again. Have You installed and inline filter? These filters tend to plug and really are designed for fuel pump systems. Also, is there rust in the tank plugging things up? I would do a bit more investigating as I run a Marvel carb, and it works great! Not saying you are not right but, Just sayin, could be fuel flow to the carb from the tank! And that fits the fact that when the engine starves for fuel and quits, enough flow from the tank replenishes the float chamber and off you go again!
DHZIEMAN is offline   Reply With Quote
Old 06-24-2018, 05:29 PM   #7
Fred K-OR
Fred K-OR's Avatar
Another thought from someone not knowing anything about Marvel carbs, but how soon does the rig quit? Is it just as you start to turn or after you are into the turn awhile? If it was just at the start of the turn, could something in your rig shift so that something grounds out your spark? If into the turn or towards the end of the turn, then like mentioned above it seems like it would be gas.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 07-10-2018, 10:30 AM   #8
1930artdeco
Finally was able to goof around with the carb. I just built up another carb and installed it with a viton tip valve. Well, it didn't shut off so had to change to a ball bearing type shut off valve-worked like a champ. Went out for a drive and except for a sticky throttle (working to fix that) it runs quite well. I just need to fine tune it now and she didn't stall out once! But I will still keep the zenith as a back up.
Mike
1957 Country Sedan
Old 07-11-2018, 09:36 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
First posting said you had a Marvel?
Old 07-11-2018, 11:09 AM   #10
1930artdeco
Yes and so far I really like it. Just need to fine tune it. But I keep the zenith as a back just in case it goes south.
Mike
1957 Country Sedan
Old 07-11-2018, 07:12 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Mike
HOW CUM ALL Bad Parts go SOUTH????---Do they bring a GOOD price, in ARGENTINA???
"Maybe" I'll sell them my stock water pump, with a 2 BLADE FAN???
Bill Confused???
"THE ASSISTANT GURU OF STUFF"
