05-22-2013, 11:03 PM | #1 |
King Pins and How Much Play
I took my front end apart over this past weekend and noticed that there was a little bit (not much) of lateral play in my king pins when removing them. My question is, how much play, if any, is acceptable in the king pins, whether it be up and down movement or lateral.
Thanks in advance |
05-22-2013, 11:25 PM | #2 |
Re: King Pins and How Much Play
Shouldn't be any up and down as the wedge bolt should stop that. Verrrry little lateral movement. They should be a push fit by hand through the bushings. ken ct.
05-23-2013, 05:33 AM | #3 |
None. With that said, you should have .001 clearance between the pins and the bushings. Honed not reamed.
05-23-2013, 06:55 AM | #4 |
Since it's apart replace the bushings, bearings with shims and felts and see if that tightens them up. The pins may still be good
05-23-2013, 07:06 AM | #5 |
Thread Tools | |
Display Modes | |
