Old 02-21-2019, 05:12 PM   #1
Mulletwagon
Default Air Filter
Need to change out the paper Unimaze element but discovered K&N makes a nice six incher that is reusable. Any thoughts on the better route to go ?
Mulletwagon is offline   Reply With Quote
Old 02-21-2019, 05:32 PM   #2
mhsprecher
mhsprecher's Avatar
Default Re: Air Filter
K&N without reservation. I suggest using the Hiboy filter rather than put one in the Airmaze.
mhsprecher is offline   Reply With Quote
Old 02-21-2019, 05:51 PM   #3
Werner
Werner's Avatar
I ust this one. It seems very good!
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 02-21-2019, 06:44 PM   #4
160B
160B's Avatar
K&N only way to go, I have the K&N E3050 on both my Model A's
The calculation on the below web site are at an engine running 2800 rpm, and the conclusion is you can use any one of three filters, they conclude any of the three filters below are adequately sized.
◦K&N offers several filters that can be used with the Air Maze housing.
◾Part # E-3050 is 3.5 inches long.
◾Part # E-9257 is 5.5 inches long.
◾Part # E-2040 is 6.625 inches long.
But the site makes this recommendation.
◦To provide some margin for the filter getting dirty, before you get around to cleaning it, I would recommend the 5.5 inch long length. I know it is an over kill, but I am currently using the 6.625 inch long one to allow for driving on dusty gravel roads and to extend my time between filter cleaning / re-oiling cycles.
http://www.model-a.org/filtering_air_into_carb.html
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-21-2019, 06:55 PM   #5
Gary WA
Gary WA's Avatar
Get rid of paper and agree to use metal screen one available from vendors or k&N.
www.whidbeymodelaclub.com
Old 02-21-2019, 08:13 PM   #6
30 Closed Cab PU
Use the K & N, also order the Service Kit for cleaning and re-oiling the filter. The 3050 is a direct replacement for use in an Air Maze. You will need to source a longer screw that holds the filter and endplate to the body of the air maze, to accommodate the other 2 longer filters.
Old 02-22-2019, 12:06 PM   #7
woofa.express
woofa.express's Avatar
I have a metal air filter. They are good at keeping out cigarette butts and bottle tops.
I know many things,
But I don't know everything,
Sometimes I forget things.
But at times I have a long memory.
woofa.express is offline   Reply With Quote
Old 02-22-2019, 12:37 PM   #8
Purdy Swoft
Purdy Swoft's Avatar
I agree , Since I quit smoking , I no longer use an air filter on mine .
Old 02-22-2019, 04:54 PM   #9
Synchro909
Synchro909's Avatar
But do you still drink???
I want to live forever.
So far so good.
Old 02-22-2019, 08:21 PM   #10
slammin
slammin's Avatar
And small children.
slammin is offline   Reply With Quote
Old 02-22-2019, 08:32 PM   #11
Purdy Swoft
Not that much .
Old 03-03-2019, 01:14 PM   #12
woofa.express
???????????????? It blocks bottle tops too.
I know many things,
Old 03-04-2019, 06:17 PM   #13
Bob-A
Bob-A's Avatar
Thumbs up Re: Air Filter
Shown below is the engine bay of my '29 roadster. The "Hi-Boy" filter came with modern hose clamps. I spray painted some repop/original clamps black with brass screws. The carb is a modern reproduction of the original Zenith. It is the "balanced" version.
Bob-A
Bob-A is offline   Reply With Quote
Old 03-04-2019, 06:28 PM   #14
old31
Bob, what kind of an intake is that?
What advantages does it have?
old31 is offline   Reply With Quote
Old 03-04-2019, 07:39 PM   #15
1930artdeco
1930artdeco's Avatar
Bob-A, How does that snorkel not melt?
Mike
1930 TownSedan (Briggs)
Still learning after all these years....
Old 03-04-2019, 08:24 PM   #16
Mulletwagon
Bob-A, Went the same air filter roue and like it. What does a balanced carb do, and how do you like your oil filter arrangement ?
Old 03-05-2019, 04:29 AM   #17
Werner
Werner's Avatar
Hello Mike,
the snorkel ist made of copper pipe. I have nearly to the exhaust pipe isolatet with fiberglass tape, because hot intake air reduces the engine power.
Werner
Citroen 11 CV, 1947
Old 03-05-2019, 09:59 AM   #18
Bob-A
Bob-A's Avatar
Cool Re: Air Filter
old31,
It is a Simmons "Swan" manifold from back-in-the-day. There is a copy of an ad for one in the book: Those Wonderful Unauthorized Accessories for the Model A Ford. The car is out of service at present and I did not run the "Swan" manifold long enough to measure any improvement. The date in the pic is incorrect.
1930artdeco,
What Werner says.
Mulletwagon,
A "balanced" carb allows the air-pressure to equalize between the carb air intake and float bowl. This prevents an air cleaner from causing a carb to run rich. Do a search and you will find more and better info in the FordBarn files. I like the filter it adds more oil to the system besides filtering. Plus, any filter is better then no filter.
The '29 roadster has been off the road for a few years now. I hope to have it back in operation this year.
Bob-A
Old 03-05-2019, 10:49 PM   #19
ALJ
It is made out of copper.
ALJ is offline   Reply With Quote
