02-06-2014, 02:22 PM | #1 |
1939 Ford center floor pan needed
I am in need of a center floor pan for a 1939 Ford convertible coupe. This is the sheetmetal piece that fits between the two wooden floorboards and fits over the transmission.
02-06-2014, 03:53 PM | #2 |
Re: 1939 Ford center floor pan needed
I will tell you they are a bit tough to find in decent shape but do show up on occasion on eBay.
Do not let anyone convince you that all you have to do is cut a hole in a '40 pan for the (floor) shift lever. The 40 pan will NOT fit the 39 opening.
02-07-2014, 02:04 AM | #3 |
I bought the 40 trans cover from Carpenter but to make it fit I added metal to it. 40 is shorter but the mod can be done so it is hard to tell it was done.
"If you always do what you have always done then you will always get what you always got." Henry Ford |
02-07-2014, 08:41 AM | #4 |
