04-25-2020, 10:12 PM | #21 | |
Re: 62 TBird Master Cylinder
Have you tried looking in the 1963 Modified/Custom section of Vintage Thunderbird Club International's Forum? https://www.vintagethunderbirdclub.n...forum.php?f=23 Link below are to articles found by searching for disc brake conversion master cylinder booster https://www.vintagethunderbirdclub.n...linder+booster
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
04-25-2020, 11:16 PM | #22 |
THANX Allan ...
On this thread - https://www.vintagethunderbirdclub.n...hp?f=23&t=8899 - The first post has a REFERRING URL which should help understand the scrubby disc conversion. The booster the poster finally used was an aftermarket 9" - 3 1/2" depth fitted to the mounting bracket. See if that helps any. It should give needed clearance on the MC.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-25-2020 at 11:22 PM. |
04-27-2020, 09:05 AM | #23 |
Thanks everyone. Sorry, wasn’t able to get out and measure it yesterday. I’m thinking the bracket at the back is what is killing me for space. Need to research these links. You all are the best. More to come!
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com |
04-29-2020, 06:00 PM | #24 |
I started researching this swap for someone with a '62 Bird and may wind up with the car myself. Those crappy Corvette masters, I would not use one. I liked that Ford dual master that was early in the thread. All better if you can match up the back of it with the OG one.
The car I'm interested in has drum brakes, new master and booster. I would leave it as is and make sure everything in the drums was ok. I saw something on the brace replacement, someone used one from a '64-'66 Bird or maybe modified it as well. The brace is pretty essential to the structure of the car. If I can find a good link, I'll post it. |
04-29-2020, 06:05 PM | #25 | |
Still working on this. Been pretty frustrating. Followed one of the links supplied and set up the new booster with the old mount and the darn from brake line port is just slightly too close to the shock tower. Going to try a 68 Mustang MC with the booster and see if that fits. Might have to put a remote fill cap on to get rid of the tall lid and bail.
Question I have is, the booster is set up for a shallow MC, the Mustang MC is deep bore. How can I convert the booster to have a longer rod? Quote:
04-29-2020, 07:40 PM | #26 |
04-30-2020, 10:21 AM | #27 | |
This is likely the answer. Even a piece of steel the right diameter would work. It does help to have friends that work in machine shops. Just measure up the differences to come up with the plug length. There is another Ford master that puts the lines on the inside. Look up Dorman M97934, but it may have a 7/16-20 port on it, you'll need that fitting. Not a big deal since you'll have to fab a line at some point. |
