02-21-2019, 05:03 PM | #1 |
40 Ford Coupe rear window seals
Anyone have a preference for rear window seals?? Drake, Carpenter, C&G or??
Paul in CT |
02-21-2019, 06:02 PM | #2 |
Re: 40 Ford Coupe rear window seals
I bought mine from DRAKE about 40 years ago. They fit great back then and still look good today.
02-21-2019, 06:08 PM | #3 |
I bought mine from Carpenter in 2005 and they fit treat.
Avoid Macs for all rubber at least. I quit using them altogether because of the problems I had with their rubber parts. (weather strip, seals, and gaskets)
Thank God this is only a hobby! |
02-21-2019, 08:12 PM | #4 |
I found Carpenter's rear windshield gaskets a bit too long for the coupe. If a coupe is what you are working on, I'd suggest you go with drake for these.
02-22-2019, 10:48 AM | #5 |
Use the Drake rear seals. Softer rubber and fit better.
02-22-2019, 01:13 PM | #6 |
Paul in CT |
