09-29-2018, 05:37 PM | #1 |
8ba weak stomach
Hi again folks. Jim here in Orrington Maine. My 37 Ford pickup came to me with an 8ba engine. It runs great but has a weak stomach. When running over 45 mph she warms up to 180 and pukes out the rad cap until it gets to 3 quarts low on antifreeze and stays there and doesn't get any hotter. There is no overflow tube on the radiator. There are no thermostats. The rad is clean and has great flow. Is this normal? I have driven it at 50 for a 200 mile tour and it never over heated. Outside temp was 75. What do I need to do?
09-29-2018, 06:17 PM | #2 |
Re: 8ba weak stomach
180 to 190 (even 195) is a good operating temperature for a flathead. It is common for these type of radiators to spit fluid until it reaches a level it likes. I am not familiar with radiators without overflow tubes. But it sounds like it is running fine to me.
GM here on the Barn has a fix if you want to run the fluid higher in the radiator. I see no reason for it, but it is something you can do. But a far as I know it requires an overflow tub to work. |
09-29-2018, 06:19 PM | #3 |
Ford didn't pressurize systems till 1941. It should have an overflow tube somewhere. The cap usually only has a rubber seal with no way to overpressure other than blowing it out the overflow if it still has a 1937 commercial radiator. Maybe someone with 37 commercial experience can relate more info.
09-29-2018, 07:52 PM | #4 |
I experienced similar overflow in my 21 stud with newer water pumps and no thermostats. I believe the flow was greater than my radiator could accommodate. I installed thermostats only to slow the flow. Has not spit a drop in 3 years.
09-30-2018, 12:42 PM | #5 | |
the lower the water the hotter it will run. Thermostats do nothing to cool an engine, only make it run at or above the stats temperature ratting. You have two problems, the resistance of 144 radiator tubes, length of them and maybe a little dirt in them. The stock pumps each deliver about 65 gallons per minute of coolant through the system. But this is reduced by the back pressure from the radiator. The solution is better pump pressure with more flow capacity. Skips pumps deliver 110 gallons per minute each at a higher pressure. The close tolerance and larger streamlined impellers in the head mounted pumps and the new turbine impellers in the 37 to 53 allow every pump Skip modifies to produce the exact same flow and pressure. Every pump is tested for at least 5 minutes on a water pump test machine and recorded in a log book. Also in over 10,000 pumps NO ONE has ever had to pay for repairs. Now due to the radiator restriction the coolant has to be FORCED through the system and in order to do this you need a WORKING pressure cap or a tight sealing stock cap and Skips 3 lb pressure valve. A pressure cap is best but the 3 lb valve which must be removed at least once a year and back flushed with a hose is the other way. The 3 lb valve holds the normal temperature pressure but opens as a safety valve is pressure is over 3.5 lbs due to over heating above 210 or a compression leak into the coolant. People using the valve have reported not loosing or adding coolant in over a year. G.M.
www.fordcollector.com |
10-01-2018, 05:31 PM | #6 |
10-02-2018, 09:51 AM | #7 |
in my roadster with a 32 radiator and an 8ba I run a 7psi cap and thermostats. it's what the 8ba was designed for. the higher pressure helps lower the formation of steam/hot spots in the block too. even still, if I fill the radiator to the top it pushes out a quart or two. this is normal.... they find their own level. modern systems have a recovery tank that allows this fluid to be pulled back into the radiator when it cools. hot fluid expands... cool fluid contracts. if you leave it "low" and it doesn't overheat or continue to puke fluid, leave it. i've been running my roadster that way for 25 years.
10-02-2018, 02:53 PM | #8 | |
Read my post above, you have a problem and don't know it. G.M.
10-02-2018, 03:48 PM | #9 |
Been running my 8BA with stock water pumps, fan shroud, 160 therms, coolant recovery tank and no pressure since 1950 without a single problem. On 80 degree and less days it runs at 160. 90 plus days it runs 180. It has gotten up to nearly 200 on very hot days on a long pull with a heavy load. Been doing this for 70 years and will probably keep doing it.
10-03-2018, 10:29 AM | #10 |
This post comes up about once a month. No one takes into account that when you heat water, it expands. If there was too much water in the system, it will spew out the over flow. If you keep adding water it will continue to spew out the over flow. Fill to radiator cap run it and forget that it spewed water out the over flow, or fill the radiator to about 1/2" over the radiator tubes. When it heats up it will not spew out the over flow.
10-03-2018, 10:51 AM | #11 | |
I did read it, sorry but I disagree. Quote:
exactly. the thermal expansion of water from 60-185 degrees in 22 quarts of water is roughly 6 quarts... guess where that water is going to go! |
10-03-2018, 11:28 AM | #12 | |
Or am I completely misunderstanding what you are trying to say? |
10-03-2018, 11:53 AM | #13 |
10-03-2018, 12:34 PM | #14 |
Read Machinery's Handbook on volume of water at different temperatures.
10-03-2018, 12:50 PM | #15 |
That's the coefficient of expansion per degree centigrade which is about the same. Water expands at different rates depending on it's temperature, but the variation is insignificant with what we're discussing here.
10-03-2018, 02:52 PM | #16 |
If you do the math according to Machinery's Handbook in deg. F, it works out to .66594 Qt. going from 72-185 degrees F.
10-03-2018, 03:06 PM | #17 |
I go with GM, I haven't used any of skips pumps, but several of my customers have. And they work quite well. Building a race motor for the track, and am considering using skips pumps, but dint;t have any budget for them yet. Still building the car and engine.
10-03-2018, 06:11 PM | #18 | |
(You guys have to learn to read those "Google" post with a little more comprehension.) |
10-03-2018, 07:44 PM | #19 | |
On a closed system filled to the just below the filler neck the size and length of the hoses will take up the expansion. G.M.
11-25-2018, 05:08 PM | #20 |
THANK YOU ALL. I had the radiator rebuilt and put in new 160 t-stats. Works perfect. Was getting cool in the Bangor, Maine area so I installed a Westwind heater. AAHHHhhh. Very nice. I can keep driving till they put the crap on the roads to melt the SNOW. I put it away today Nov.25. Wow nice. Thank you all again.
