03-07-2019, 06:20 PM | #1 |
Cowl lamp harness routing
Rewiring my '34. Anyone know the correct routing for the cowl lamp harness? One end connects to the lighting harness near the light switch at the bottom end of the horn rod, and the other 2 ends go to the cowl lamp pigtail harnesses on either side inside the cab near the windshield mounts. But where does it go thru the firewall? Thru the hole with the main harness (along with the wiper hose and temp gauge tube and gas gauge tube)? I can't remember seeing any photos that show 2 harnesses going thru the firewall there.
Document your car with CollectorCarCompanion Last edited by JMFL36; 03-07-2019 at 08:04 PM. |
03-08-2019, 04:59 PM | #2 |
Re: Cowl lamp harness routing
Document your car with CollectorCarCompanion |
