Old 01-10-2018, 09:28 AM   #1
wgreeley
wgreeley's Avatar
Default 36 Ford radio head repair
I wonder if someone has taken apart a 36 Philco FT-9 control head. I need to remove the switch for repair, but the dial gears are in the way. Does anyone know how to remove the dial gears. The right hand gear is captive to the center dial gear which doesn't want to come off. Both gears rotate freely.
wgreeley is offline   Reply With Quote
Old 01-10-2018, 04:21 PM   #2
wamnram
wamnram's Avatar
Default Re: 36 Ford radio head repair
There is a small wire clip behind the gears that holds them in. maybe someone else on here will have a picture of it.
Wayne
wamnram is offline   Reply With Quote
Old 01-10-2018, 08:09 PM   #3
Brendan
Brendan's Avatar
looks like a clock!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-13-2018, 08:40 PM   #4
wgreeley
wgreeley's Avatar
Thanks Wayne. That was it. A little DeoxIT contact cleaner and the switch was fine.
Old 09-23-2023, 09:37 AM   #5
jgclark1957
jgclark1957's Avatar
Hello;
Is it too late to get further information about this thread?
I am also attempting to remove the switch from my Ford Philco FT9 Radio Head.
I am encountering the same issue that "wgreeley" ran into. The right gear is retained by the center gear and I can't seem to remove the center gear. There is a very small spring that is connected between the 2 gear shafts and clips to the hole in the center gear. I have disconnected that spring but I still can't figure out how the center gear is removed.
Any help would be greatly appreciated.
Thanks in advance.
Jim
jgclark1957 is offline   Reply With Quote
