07-20-2020, 06:36 PM | #1 |
Gets warm and quits running?
The Cape Man asked me to post to see if help can be found for his issue:
Background: 1947 Ford, 59AB flathead , good carb with phenolic spacer, new (good) coil, crab distributor recently set up on distributor machine. Issue: Runs great until temp get about half way on guage (warmed up but not hot) suddenly quits running. Wait 10-20 minutes will start up and go for awhile. Looking for assistance, thanks. |
07-20-2020, 06:48 PM | #2 | |
Re: Gets warm and quits running?
What do you consider a "new (good) coil"?
07-20-2020, 06:55 PM | #3 |
Coil or condenser. I've had 2 coils go intermittent when warmed up in the past.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
07-20-2020, 06:56 PM | #4 |
It has taken me a long time for my brain to remember that "new does not = good". This is especially true of condensers and to a lesser extent coils. NOS old Ford coils are never good but are nice to be rebuilt. There is very little if any QC going on in manufacturing these days. It is cheaper to just give the customer another unit.
07-20-2020, 07:54 PM | #5 |
As stated above, classic symptoms of a capacitor or coil breaking down as they warm up. (now watch, it will end up being a fuel issue! )
07-20-2020, 07:58 PM | #6 |
07-20-2020, 09:08 PM | #7 |
Mine was coil. Took 4 new coils to get one that was good...........
07-21-2020, 10:11 AM | #8 |
Thank to all for the input, "Cape Man" Ed is hard at work chasing his problem. He said any and all ideas are welcome. Lou B.
07-21-2020, 10:38 AM | #9 | |
is a stock Ford coil new or old it will still fail on a hot day in traffic when the engine gets hot. I have tested hundreds of stock Ford coils and NEVER found one that did not fail when hot. G.M.
www.fordcollector.com |
07-21-2020, 10:46 AM | #10 |
GM.......you are exactly right. All I really know is that the one I have now is not breaking down-yet. I was told my NAPA "good" coil was made in Mexico and even then it is cheaper for them to replace them rather than build a quality one.
07-21-2020, 01:53 PM | #11 |
Had a similar problem on a ‘35 convertible sedan.
Got a coil adapter and two new NAPA coils. Did the same thing. It would run poor after about 15 minutes. Wouldn’t restart until it sat maybe half an hour. Sent the old Ford coil to Skip. Car has run perfect ever since. That was 3 or 4 years ago. Now if it has run for an hour and you shut it off it will start right up as soon as you hit the starter button. Skip, the magic dragon. The only way to go. Aaron Griffey Hayward, taxafornia |
07-22-2020, 01:06 AM | #12 | |
Just gone through that -3 new condensers to find one that is good. In the end it was one of tubmans that solved the issue. The trouble is having replaced the condenser with something new (and assuming it is good ) when the problem continues you go down a rabbit hole looking for the fault some where else
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
07-22-2020, 08:43 AM | #13 | |
07-22-2020, 09:09 AM | #14 |
Vote for bad coil. Send it to Skip.
07-22-2020, 09:30 AM | #15 |
If using a stock type coil, send it to Skip anyway, even if the current problem is the condenser. I always liked Chuck Yeager's quote "Never wait for trouble" (even though it was uttered during a GM parts advertisement!)
07-22-2020, 07:14 PM | #16 |
Chuck Yeager was 97 in February this year. He’s still with us.
07-23-2020, 03:30 PM | #17 |
"Cape Man" called the other night, he was making some changes as suggested here and keep me updated. It's been crazy hot around here (tough on us old guys), I have not heard from him, but will try to keep you updated. I agree it is an electrical gremlin (coil or condenser breaking down when hot).
07-23-2020, 04:29 PM | #18 |
Condensers seldom fail when hot. In most cases where the condenser is at fault, it was leaking and causing the coil to over heat. Then the spark is weak.
When they fail because of heat they stay broken and do not perform correctly when they cool down.
TomO |
07-24-2020, 02:31 PM | #19 |
Tom, I hate to tell you but condensers fail all the time
from heat. When Skip does a coil for some one he asks them to send condensers so he can heat them up to hot test them. They work cold but when they get to about 200 they fail and will work again when they get cool. G.M.
07-24-2020, 09:18 PM | #20 | |
