06-09-2019, 03:49 AM | #1 |
1946 Generator Mount Stud.
Have recently had a failure of the generator to inlet manifold stud.
Sheared and lost generator plus fan into radiator. A spare manifold had a 1/2 unc stud fitted. the broken one had a 9/16 unc stud fitted. Part No: 357730-S7. 3rd Generation have them in stock.Presume these would be 9/16 unc. Is the 9/16 unc the correct thread and are these just normal specs as opposed to HT. Phil NZ |
06-09-2019, 05:49 AM | #2 |
Re: 1946 Generator Mount Stud.
Phil, Yes 9/16, NC on the manifold end and NF on the nut end.
06-09-2019, 10:38 AM | #3 |
Use Locktite.
06-09-2019, 02:23 PM | #4 |
And don't over tighten the nut or the belt.
06-09-2019, 02:39 PM | #5 |
Thanks very much for confirmation and suggestions as always
Phil NZ |
06-09-2019, 07:33 PM | #6 |
06-09-2019, 09:22 PM | #7 |
06-10-2019, 01:56 PM | #8 |
What was your failure? did the stud pull the threads out of the intake or did the stud snap?
06-10-2019, 03:15 PM | #9 | |
Have another with a damaged thread which I recovered by going out to 5/8 unc. Phil NZ |
06-11-2019, 01:30 PM | #10 |
Yes I've seen the studs break before. I guess from over tightening? Regardless, they were probably never engineered to last this long.
06-11-2019, 07:30 PM | #11 | |
Phil NZ |
