Old 05-01-2015, 01:34 PM   #1
d.j. moordigian
d.j. moordigian's Avatar
Default Restoration Qs...Forged throttle levers
I didn't find anything in the 2011 JS,....but I could have missed it..
The throttle "slits" are different between these 2 forged arms. I believe
the Holly is on the right and the Zenith on the left...correct?
Any other information?
Thanks,..Dudley
d.j. moordigian is offline   Reply With Quote
Old 05-01-2015, 02:39 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Restoration Qs...Forged throttle levers
Dudley,
Zenith on the right and Holley on the Left.
Have you happen to have a extra Forged Holley, need one to complete my Holley ?
Also could use a couple of Forged Choke Levers (no leg on bottom) ?
Ron
Ron in Quincy is offline   Reply With Quote
Old 05-01-2015, 02:54 PM   #3
d.j. moordigian
Originally Posted by Ron in Quincy View Post
Dudley,
Ron
Ron,
I knew I could count on you !!
I had too cut the Holley out of the carb,...sooo I'm short also.
Yes,...I know your looking for the bottom "no leg" lever. I don't have any
myself.
You going too Turlock Sunday ?
Old 05-01-2015, 04:36 PM   #4
d.j. moordigian
Originally Posted by 1930 coupe View Post
There is no reason to cut any parts out of a carb.
Heat the area around the stuck part with a acetylene torch until it turns red, then dip it in water and the part will come out very easy with NO DAMAGE AT ALL.
Your correct,...and I did !
This carburetor was real bad! Must have heated the bole 10 times and still
couldn't get the removable well out..
