Old 11-18-2019, 09:43 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 8ba Heads 7RT or EAB
Have an 8BA fitted to 38 PU. Doing a bit of work on it. Presently have inlet manifold off to check all valve clearances.
This PU runs well with approx 12500 mls on rebuilt engine. I did not do the work. Its presently fitted with 8RT heads C/R 6.8 :1 . I have a good set of EAB heads C/R 7.2 :1 I understand. Would there be any notticeable improvement with changing out these heads. Engine pretty much stock 40 over, Max 1cam and single 97 carb with a newly rebuilt Charlie NY chev distributor fitted with adjustable mech and adjustable vacuum advance. Not sure what present piston to head clearance is.
Thanks,
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 11-18-2019, 10:00 PM   #2
51504bat
51504bat's Avatar
Default Re: 8ba Heads 7RT or EAB
I'm running EAB heads on the 8ba in my '39 p/u. Stock rebuild with a supposed Merc cam but that is it came with a bunch other other Merc parts I bought and the machinist said it was in better shape then the one that was in the engine at the time. Other than the cam(?) and EAB heads, a Bubba mechanical advance distributor, and a Charlie NY carb its 100% stock. It runs great. I think you'll notice an improvement with the EAB heads over the 8rt ones you're running now but that's JMO.
Old 11-18-2019, 10:04 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
IMO it won't make that much difference unless the heads are shaved/massaged to get the much touted .050" head to piston clearance.
Old 11-19-2019, 12:41 AM   #4
Phil Gillespie
Yes thats my thinking also. Coud remove one head and check where the 8RT head is at with piston to head clearance and go from there.
Or just complete valve clearance checking and keep on trucking.
Phil NZ
Old 11-19-2019, 01:06 AM   #5
Tinker
Tinker's Avatar
Depends on what you want to achieve. You could clay or make tin foil balls. People can get too aggressive and over mill heads. I'm a stocker with a bit of mill and lift.
Always something that when people post, I have some old heads and bolting them on. Well, but ya sure you know what condition your condition is in?
Old iron heads are capable of 8:1.
A good question for Ol Ron and others.
Old 11-19-2019, 02:21 AM   #6
Lawrie
Lawrie's Avatar
8rt heads are truck ones ,and have a larger chamber.
I sure noticed the difference on our 33 with using heads with the larger chamber,
Less MPG and torque.
Lawrie
Old 11-19-2019, 04:35 AM   #7
JWL
Yes, there will be a noticeable power, efficiency, and drivability improvement if you make the proposed head swap. If you read my book you will see the actual numerical differences which I do not remember as I write this.
JWL is offline   Reply With Quote
Old 11-19-2019, 04:52 AM   #8
Phil Gillespie
Thanks for confirmation on this one John. I do actually have a copy of your book and will again revisit it and refresh myself.
Just to recheck with the foil balls and get that 50 thou piston to head clearance.
Phil NZ.
