Old 04-02-2020, 04:50 PM   #1
poolplayer1
Default 1955 Ford ranch Wagon Parking brake question?
I am trying to replace some missing parts in the parking brake system of my ranch wagon. I need the cable that goes from the equalizer rod to both rear wheels. I also need the equalizer rod. I found both at macs but looking at the pictures of both,I can't figure out how the cable would hook up to the rod.
If I'm not mistaken,the threaded part of the rod connects to the cable but I don't see how that can be. I know that this is asking too much but I was wondering if any of you could (whenever you can) look at the 2 parts and than tell me if they can be connected together.I don't want to order both and than find out that they will not work in my wagon. Here are the part #'s for both.
Cable- 49-27102-1
Equalizer Rod= 49-29668-1
Thank you very much for your help.
poolplayer1 is offline   Reply With Quote
Old 04-02-2020, 05:27 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 1955 Ford ranch Wagon Parking brake question?
Do you have the equalizer yoke? Its a semicircular conduit for the cable. The cable passes through the yoke and attaches to the rear brakes. The yoke is attached to the rod with an adjusting nut and a lock nut.
The yoke looks something like this:
CASCO catalog, page 11
Part #2A602
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 04-02-2020, 07:56 PM   #3
dmsfrr
dmsfrr's Avatar
This photo isn't of a Wagon, but it may be similar.
The parking brake cable from under the dashboard ends in the threaded rod on the left. It attaches to the (twisted) flat bar that has another adjustment rod near the right end that attaches to the U shaped brake cable holder.
dmsfrr is offline   Reply With Quote
Old 04-03-2020, 01:06 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: 1955 Ford ranch Wagon Parking brake question?
See if this helps -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-03-2020, 09:36 AM   #5
54vicky
54vicky's Avatar
that is a real world picture of the set up.better than a picture in a manual.that dms posted
54vicky is offline   Reply With Quote
Old 04-03-2020, 02:20 PM   #6
poolplayer1
Thanks to all for your great help. So,looks like I am missing the part labeled 2A602 in the drawing. Thats what holds the cable. Now,if you look at the rod labeled 2628 how it hooks into the equalizer bracket and tru the equalizer bar and than the cotter pin,I don't see how the rod at macs would work here.The rod at macs does not have the hook facing down where it would go tru the bracket unless I am not seeing it correctly. What do you guys think? I hope I can find the 2A602 cable holder part.
Old 04-03-2020, 02:42 PM   #7
poolplayer1
Thanks Guys,I found the correct one on Ebay.
Old 04-03-2020, 03:01 PM   #8
dmsfrr
dmsfrr's Avatar
Originally Posted by poolplayer1 View Post
.... So,looks like I am missing the part labeled 2A602 in the drawing. Thats what holds the cable. ... I hope I can find the 2A602 cable holder part.
Here's an example but I'm sure you can also find it new or used at other places.
https://www.classictbird.com/Holder-...uctinfo/2A602/
Old 04-03-2020, 05:04 PM   #9
poolplayer1
Thanks dmsfrr for your help. Also thanks to Kultulz for the diagram of the parts that I needed. And,of course thanks to all that helped with opinions and suggestions. This group is full of talented people and I really apreciate all the help that you guys give to all here.
Old 04-07-2020, 02:11 PM   #10
poolplayer1
Does anyone know if the part # 6L5Z-2A602-A is the same part as the 2A602-A like the one in the drawing above? Thanks for checking.
Old 04-07-2020, 05:51 PM   #11
KULTULZ
KULTULZ's Avatar
6L5Z 2A602-A is for a 2006 RANGER.
You will be looking for B8SZ 2A602-A NOS.
- WHY IS IT ... -
Old 04-07-2020, 07:06 PM   #12
Dobie Gillis
Looks like it might be easy to make one out of a piece electrical conduit.
Old 04-07-2020, 08:49 PM   #13
poolplayer1
Thanks Kultulz. Apreciate your help.
Old 05-03-2020, 05:42 PM   #14
steve fritz
I hate to jump in here on this old post....but KULTULZ posted a nice detail of the under car parking brake system on this thread , and I have a question on part number 2153 , which is the bracket that the parking brake cable runs through just before it attaches to the swing lever that pulls on the rear cables. If you look at that KULTULZ diagram you will see it. My question is if that 2153 bracket is a separate piece that bolts to the frame OR is it a welded on piece that remains with the car frame.???
I also am restoring a 55 wagon and ran into this problem this week. For some reason that 2153 bracket is missing on my project. I just need to know how to go about finding one. Hopefully its a "bolt on " piece and not permanently welded to the frame.
Of course if anyone has a parts car and would want to sell me that piece I would really appreciate it. I can always make it work , bolt up or weld on.
Thanks for your time and reply.
Steve
steve fritz is offline   Reply With Quote
Old 05-03-2020, 06:00 PM   #15
dmsfrr
dmsfrr's Avatar
Originally Posted by steve fritz View Post
... My question is if that 2153 bracket is a separate piece that bolts to the frame OR is it a welded on piece that remains with the car frame.??? ...
Steve
If it helps...
I have two 'not a wagon' examples in the garage, a '55 and a '57.
Both of them have the (2153) cable mounting bracket riveted to the frame.
Old 05-03-2020, 08:05 PM   #16
steve fritz
dmsfrr....thanks for your reply. I was afraid of that. Anyway , I will have to try to chase down somebody with a parts car and see if I can get them to take the bracket off.
Not an easy job I am sure.
In the mean time , would you mind just taking a picture of that bracket and its location on the frame? That will at least give me an idea as to how it should be mounted and where. I may have to end up fabricating such a bracket and then I would have an idea as to where to weld it in place. If you have better luck than me posting pictures to this forum , please do. Otherwise , if you can send a text to me with the cell phone picture , my cell is 608-738-1861 and my email id is [email protected].
I really appreciate your help. No hurry , just do when you have time.
Thanks again,
Steve
Old 05-04-2020, 07:31 PM   #17
steve fritz
I found the bracket , it bolts to the left rear lower ear on the transmission cross member.
Problem solved. Thanks to all that replied.
Steve
Old 05-04-2020, 07:41 PM   #18
dmsfrr
dmsfrr's Avatar
Glad you found it. The location of one on the frame of a '55 Tbird probably wouldn't have helped at all.
Thread Tools
Display Modes
