Old 10-04-2019, 10:36 PM   #1
davids2toys
davids2toys's Avatar
Default 36 Ford steering box question
Hi All,
Very new to the old Ford world. I just bought this car from the original owner earlier this year. The steering box was empty, I filled it up and the next day it was empty again because it all leaked out on the ground. Any ideas what is leaking?
Thanks...David
davids2toys is offline   Reply With Quote
Old 10-04-2019, 11:44 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 36 Ford steering box question
is it leaking out the light switch or the sector shaft?, different fixes
Old 10-05-2019, 06:28 AM   #3
Terry,OH
Terry,OH's Avatar
The leak at the light switch is usually fixed by removing the tube 40-3597 and soldering the tube to it's mounting plate. If the leak is at the sector and pitman arm the sector shaft seal in the sector housing should be replaced with a CR11209 seal.
If the oil all leaked out overnight you may be missing something. There are drawings in the parts books showing the assembly.
Old 10-05-2019, 07:39 AM   #4
alanwoodieman
FYI- 36 steering box is a one year only design-it has needle bearings as opposed to bushings, I have worked on several and if the box has been without oil for very long chances are the bearings will be bad. do as terry oh said.
Old 10-05-2019, 08:49 AM   #5
JSeery
JSeery's Avatar
What are you putting in it for lubricant? They tend to leak with thinner lubes.
Old 10-05-2019, 09:20 AM   #6
davids2toys
I am using the lube I put in the rear and tranny, it is the 600 wt from Mac.I will have to put more in and observe where it is leaking from. I know it was dripping from the front of the shield so it could have come from either place. Is the shield easy to remove so I can see specifically where it is leaking?
I am used to working on my ERA AC Cobra and this is a whole different animal!
Old 10-05-2019, 09:27 AM   #7
tubman
tubman's Avatar
To temporarily get by. try some John Deere "Cornhead" grease. It has solved a lot of leakiy steering box problems. Do a "Search" here and on the "H.A.M.B.".
Old 10-05-2019, 09:33 AM   #8
JSeery
JSeery's Avatar
What they are calling 600w is around SAE 140 gear lube. Any other year gear box Cornhead gear lubricant is a good option, but not sure with the roller bearings. I think what you are referring to a shield is the light switch housing. It comes off by sliding the bale off to the side and twisting it a little.
Old 10-05-2019, 09:36 AM   #9
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube....................NO leakee.
Available from Restoration Specialties, Escondido, CA
Paul in CT
Old 10-05-2019, 12:11 PM   #10
davids2toys
In the manuals for this year it calls out gear lube, so that is what I used. The same that is called out for the rear and tranny.
No, the shield I am referring to is not the light switch housing, this shield is underneath the car and goes beneath the light switch housing and steering box.
I just watched a video on that Pennrite lube, looks awesome. Looks like a nice fix for a car that is not going to see a lot of miles beside some cruise nights, thanks
Old 10-05-2019, 12:46 PM   #11
JSeery
JSeery's Avatar
If you are wanting to go by the manual, why are you using Mac's 600w, that's not something Ford ever recommended! Ford recommendation for transmission was gear lubricate, SAE 90 or 100 Winter & SAE 160 Summer. And for rear axles, Extreme Pressure (EP) SAE 90 or 100 Winter & SAE 160 Summer. 600w was a brand name of a steam engine lubricant. Ford later (by at least 1940) updated the transmission recommendation to Mild EP gear lubricant. In todays terms I would use a GL4 multi grade gear lube for transmission and GL4 or GL5 multi grade for the rear axle.
Old 10-05-2019, 06:00 PM   #12
davids2toys
Because I believe that is what Macs called out for this car on their site, so that is what I got. I believe the manuals just called out some weights and temps. Next time I will be more careful. I am sure it will be fine for what i am using the car for
Old 10-05-2019, 07:08 PM   #13
JSeery
JSeery's Avatar
Ya, it's a sales gimmick some of the suppliers promote. Not that it is going to damage anything, but think you are better off using know quality gear lubricants. As I am sure you will find out Mac's is not the best source of information or parts (that said I order from them from time to time). The best is NOS for most parts when you can get them. Several regulars here on the Barn have a lot of NOS items. When that is not an option, it is nice to deal with suppliers that know and understand these vehicles, again a lot of sources right here on the Barn.
Old 10-06-2019, 12:07 AM   #14
davids2toys
understood
Old 10-06-2019, 06:42 AM   #15
A bones
A bones's Avatar
Have you tried Joe's Antique Parts? Nice folks very knowledgeable.
Uxbridge Mass. open Mon to Thur 8:00-4:30.
1 800 508 3980 for orders, 1 508 278 3980 for orders and support.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 10-06-2019, 07:12 AM   #16
cajunfirehawk
cajunfirehawk's Avatar
Paul in CT
Is one bottle enough for the avg 36 steering box?
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 10-06-2019, 11:25 AM   #17
davids2toys
I don't think so, maybe when I first got the car. The name looks very familiar. I will keep them in mind. Thank you
Old 10-06-2019, 11:30 AM   #18
davids2toys
Great question! I looked into this stuff a little. Videos on you tube show it in a bottle but they sell it in a tube in their catalog, page 24 it is sold in a 450 gram tube for 19.00. The stuff in the bottle looks great and after some heating should be easy enough to pour in the box
Old 10-23-2019, 10:17 AM   #19
davids2toys
I ordered 2 bottles and so far it is not leaking out at all.Lets see what happens when it is running and heats up because of the location next to the exh manifold. The shipping was expensive and the same whether I ordered 1 bottle or 12, so I ordered 2
Thank you...Dave
Old 10-23-2019, 10:45 AM   #20
Kerk
I have tried to contact you re: CT V 8 club but no real luck ! Try Ted Ristau 29 Hawthorne Dr. Noralk, Ct 06851-4113 R.G. 131 Tel. # 203-847-0078 I am not much good with computers as you can see !!Kerk # 978-372-6012
Kerk is offline   Reply With Quote
