07-26-2021, 01:05 PM | #1 |
starter click?
For a couple of days I have experienced an occasional click when starting my 52 Vic. Not all the time but once in a while. i cant tell if it is my ignition switch or the starter or the voltage regulator. The battery is ok and the car will eventually start. Any thoughts?
07-26-2021, 01:27 PM | #2 |
Re: starter click?
Sounds like a poor electrical connection(s)......clean the battery terminals, as well as all grounds to the engine. Also clean the starter motor terminals. Also check the battery cables for corrosion. If that does not solve your problem.....check the amperage draw on your starter...it may be on life support.....
07-26-2021, 01:56 PM | #3 |
Re: starter click?
You probably need a new starter solenoid. Looks like this.
https://www.oreillyauto.com/shop/b/c...k-1952-ford-f1 Make sure the one you buy matches the one you now have. Last edited by 19Fordy; 07-26-2021 at 02:01 PM. |
07-26-2021, 03:07 PM | #4 |
Re: starter click?
What kind of "click"?
A chattering click could be corroded or loose connections, or weak battery. A "one click" and no crank is probably the solenoid. Sometimes it takes a few clicks before the solenoid makes a good contact. In either case, replace. |
07-26-2021, 03:45 PM | #5 |
Re: starter click?
It COULD be a problem with the solenoid itself. It could also be a poor connection anywhere along the BATTERY Cable circuit. It COULD also be a bad GROUND at the "Start" button. The fact that it DOES eventually start leads me to believe the solenoid IS NOT the problem. DD
07-26-2021, 04:38 PM | #6 |
Re: starter click?
07-26-2021, 05:51 PM | #7 |
Re: starter click?
Thank you all! Solenoid gets the vote. I'll let you know. Much appreciated!!!
07-26-2021, 08:07 PM | #8 | |
Re: starter click?
Ya know, it sure doesn't cost much (like about $0.00) to go through and clean all three connections on the solenoid, two at the battery, one at the battery GROUND cable, plus the grounding of the Start button to the dash.....any of which being dirty/corroded or loose, could cause your symptom. Just sayin'! DD |
