Old 09-21-2019, 11:06 AM   #1
Russ/40
Russ/40's Avatar
Default Rear main leak to clutch
I'm curious, when a rear main leaks substantially, does it foul the clutch? Or, does the leak somehow bypass the clutch. Also, is the long style clutch on a trimmed A flywheel more suseptable to oil fouling?
Russ/40 is offline   Reply With Quote
Old 09-21-2019, 11:29 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Rear main leak to clutch
I've had model A's most of my life and I have never had oil from a leaking rear main bearing get in the clutch . I suppose if the leak was severe enough it could happen but the leak would probably be too bad for regular use .
Old 09-21-2019, 11:40 AM   #3
Ruth
When my rear main was leaking the flywheel seemed to 'fling' the oil out where it would collect on the inside of the bell housing then run out the bottom. never got to the clutch.
Old 09-21-2019, 12:43 PM   #4
Patrick L.
Patrick L.'s Avatar
Its pretty hard for the oil to get tangled up in the clutch.
Old 09-21-2019, 04:53 PM   #5
Synchro909
Synchro909's Avatar
A combination of gravity and centrifugal forces prevent oil getting to the clutch. I had an engine once that leaked oil out the back so badly that when I stopped, oil would flood out onto the road and often enough, leave a puddle a foot accross. While I was driving, the spinning flywheen kept the oil flung out against the inside of the bell housing. When the motor was turned off, gravity did its thing and the oil found its way out. NONE got on the clutch!
Life's journey is best undertaken slowly.
Old 09-21-2019, 05:00 PM   #6
Purdy Swoft
That's the way that I believe it works and it leaks after the engine is shut down .
Old 09-21-2019, 05:15 PM   #7
Werner
Werner's Avatar
Hallo Russ, on my A, the clutch slipped because a mixture of grease and oil touched the friction lining. Remedy brought the repeated spraying with a big lot of brake cleaner.
Beste Gruesse aus Deutschland,
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 09-21-2019, 11:35 PM   #8
Russ/40
Russ/40's Avatar
What makes me ask the question, is if I let my car sit for a few weeks, The clutch has no chatter and is smooth. If I really work the car like long drives with lots of hills, the clutch begins to chatter. The longer I drive it, the worse the chatter gets.
Old 09-22-2019, 03:12 AM   #9
Patrick L.
Patrick L.'s Avatar
You could remove the inspection plate and take a look. You might also check that the pressure plate fingers all make contact with the release bearing at the same exact time.
Old 09-22-2019, 11:04 AM   #10
Russ/40
Russ/40's Avatar
Your right, I should do that. I just hate pulling the floorboards. The floormat gets buggered up a bit more every time. I'm pretty confident the clutch fingers are ok.
Old 09-22-2019, 12:36 PM   #11
Patrick L.
Patrick L.'s Avatar
I can relate to the floor mat thing. Mine is now one of those 2 piece units.
But generally a chatter is from a warped flywheel, pressure plate fingers too far out of adjustment or clutch housing out of alignment. Of those, the finger check the easiest with a long feeler strip.
I think its seldom that a chatter is caused by a soaked disk.
Old 09-22-2019, 02:48 PM   #12
Kohnke Rebabbitting
I Agree, Mr Patrick, and I also have never seen oil on Flywheel, or pressure Plate.
The ones I have, ( Not Model A ) , always slipped, rather then chatter.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 09-22-2019, 02:59 PM   #13
Kohnke Rebabbitting
Herm.
Thread Tools
Display Modes
