Old 08-12-2019, 02:51 PM   #1
Werner
Werner's Avatar
Default Push down ignition switch
Hi, I'm looking for a more nice ignition switch, like the originally built with to press in to start. Is this:
https://www.macsautoparts.com/ford_m...head-only.html
the right replica?
Thanks in advance!
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 08-12-2019, 04:38 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Push down ignition switch
That switch works well and resembles the original once installed. I have one and it has a nice solid click with a detent in the "on" position. It is only an on/off switch that resembles the original.
The original is referred to as a "pop-out" switch. It looks different and functions differently but accomplishes the same thing. It pops out in the "on" position and to shut "off" you push it in
There are pictures and discussion in this thread.
https://www.fordbarn.com/forum/showthread.php?t=30610
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-12-2019, 04:52 PM   #3
CHuDWah
CHuDWah's Avatar
the right replica?
Thanks in advance!
Just to be clear, the original "pops-out" so you can start the car. You push it in when you stop. (And there's a whole lot more involved in starting and stopping. ) Anyway, the switch you linked "Looks and mounts like the original but does not pop out...On-off style switch."
WANTED: original flux capacitor and Mr. Fusion Home Energy Reactor. Must be NOS and reasonably priced.
CHuDWah is offline   Reply With Quote
Old 08-12-2019, 05:01 PM   #4
rotorwrench
rotorwrench's Avatar
Original Electrolock pop out switches sometimes come available on flea-pay or on the swap meet sections of forums like the Ford Barn. They have to be scrutinized for their originality since reproductions were made of them for a long time but they did not have the characteristics of originals. The originals can be rebuilt to some degree if the key parts are still serviceable.
Original Briggs & Stratton type keys are out there as well but may require some lock cylinder or key cutting to get them to work correctly if an original doesn't come with keys
Old 08-12-2019, 05:27 PM   #5
CHuDWah
CHuDWah's Avatar
Dang, beat me to it!
Assume that's your truck in your avatar - pretty sweet. Always liked the "square" cab 28 - 29.
Old 08-12-2019, 06:39 PM   #6
CWPASADENA
CWPASADENA's Avatar
Personally, I would not buy the one from Mac's.
This is probably made in China and we have had nothing but problems with electrical stuff from China.
Also, the part behind the dash panel is quite large and you may have interference problems with the wire connections.
If you want an original "Pop-Out" switch, contact `Dick Crabtree mbcrabtree@aol.com
Dick restores the original switches and also will help you with all the locks on your Model A or Early V-8 Ford.
Excellent work at fair prices.
Ford also sold a replacement ignition switch fro the Model A.
They are very good quality. They are around and I would consider one of these if you did not want to go for an original Pop-out Switch.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 08-12-2019, 08:54 PM   #7
Dave1931Pickup
I agree with CWPASADENA. I bought mine from Dick Crabtree. Excellent work and very fair price.
Dave1931Pickup is offline   Reply With Quote
Old 08-13-2019, 04:05 AM   #8
Werner
Werner's Avatar
Hello everybody, at first thank you all for the many helpful answers!
No, I do not use China scrap too! I already wrote to Bob Crabtree several weeks ago if he also sent to Germany. But unfortunately I did not receive an answer.
Yes, it should be a pop-off switch, because I like all these fine mechanic nicely. I will go to the search.
Werner
Citroen 11 CV, 1947
Old 08-13-2019, 08:20 AM   #9
updraught
updraught's Avatar
That one sold by Macs looks like the USA made Nurex switch.
https://www.nurex.com/pop-out-ignition-switch
The $13 one will work, well, temporarily
https://www.macsautoparts.com/ford_m...tches.html&p=1
updraught is offline   Reply With Quote
Old 09-21-2019, 04:29 PM   #10
Werner
Werner's Avatar
Good evening everyone,
today I received from Dick Crabtree a restored original Popp-Off ignition switch. Very nice quality! It's a great feeling to press the crisp key lock. Thanks again to all forum participants for the helpful hints!
Werner
Citroen 11 CV, 1947
Old 09-22-2019, 09:08 AM   #11
CWPASADENA
CWPASADENA's Avatar
I am glad this worked out for you. Thanks for letting us know.
Often, we make suggestions but never know if the problem was solved or what the outcome was.
You will enjoy having a "Pop-Out" ignition switch.
Take care,
Chris W.
Old 09-22-2019, 07:43 PM   #12
Mike Peters
Mike Peters's Avatar
I also have a restored popout from Dick Crabtree.
Werner: The three small mounting screws will be difficult to line up and install for your new popout in your dash panel. Go slow, be patient, and it WILL go together. Be sure to use the bakelite wire nut Dick furnished so you don't get any electrical shorts.
I also enjoy the feel of original popout switches!
Mike Peters is offline   Reply With Quote
Old 09-23-2019, 06:09 AM   #13
Werner
Werner's Avatar
Hallo Mike,
thank you for the hints. Yes, the complete ignition is already installed. Yes, that's tight fiddling.
But rather 100 ignition locks change than 1 again the rear leaf spring!
Werner
Citroen 11 CV, 1947
Old 09-23-2019, 10:00 AM   #14
Brentwood Bob
Noticed a clip for each spark plug brass strip. From here it looks like you managed to drill thru the post on the distributor body.
Did I see this correctly?
Brentwood Bob is online now   Reply With Quote
Old 09-23-2019, 10:54 AM   #15
jwilliams81
jwilliams81's Avatar
What is Dick Crabtree's contact information?
1931 Murray Town Sedan. Black body with Apple Green pin stripe. Cincinnati, OH
jwilliams81 is offline   Reply With Quote
Old 09-23-2019, 02:44 PM   #16
Werner
Werner's Avatar
Hallo Bob, I see you have looked very carefully! Right, the bronze strips are secured on the distributor pins with the twisted wires. The twisted wire is bent to a "S". As a result, it pushes the strip with a little bias down. To loosen the strips, the S-wire is turned 90 degrees to the side.
Hallo jwilliams, please look # 6.
Werner
Citroen 11 CV, 1947
Old 09-23-2019, 02:58 PM   #17
Brentwood Bob
Probably a stainless steel wire. I like that. Improves the contact, and easy to do.
Will give it a try.
Old 09-23-2019, 03:53 PM   #18
F.M.
His phone is 605-487-7229 Cell 281-615-2261 E-Mail mbcrabtree@aol.com
F.M. is offline   Reply With Quote
