Old 08-31-2019, 06:34 AM   #1
shew01
Default Oil Change Interval
Im still new to Model As. I purchased my first one a little over a week ago, and it has been a blast to drive.
The red Les Andrews book (page 3-6) recommends oil changes every 500 miles. The book appears to have been published around the year 2000. My As previous owner had an air filter installed and says he changed oil every 1000 miles. The red book (3-1) indicates that no air filter is source of dirt in the oil.
How often do you experienced owners change oil?
Old 08-31-2019, 06:36 AM   #2
shew01
Default Re: Oil Change Interval
Would todays oil be significantly better than what it was 20 years ago (roughly when the red book was published) to merit a 1000 mile change interval?
Old 08-31-2019, 07:02 AM   #3
Ray64
Ray64's Avatar
I had my engine rebuilt last year and I plan on oil change at 1.000 miles religiously
Ray64 is offline   Reply With Quote
Old 08-31-2019, 07:18 AM   #4
chap52
chap52's Avatar
1000 works for me. The drained oil still looks good at that time. Chap
Old 08-31-2019, 07:46 AM   #5
30 Closed Cab PU
I have a rebuilt motor and an air filter. Prefer to change oil at 500 miles. It gets me under the car to inspect things and grease the zerks, and reminds me to check a long list of things like lubing the generator, distributor, distributor cam, tire pressure, lug nuts, etc., etc. Worth it to me if it extends the life of the motor and gives me peace of mind.
Old 08-31-2019, 08:24 AM   #6
Jacksonlll
Jacksonlll's Avatar
500 if you don’t drive it much. A 1000 or more on long trips over a short time.
Old 08-31-2019, 11:12 AM   #7
Ernie Vitucci
Good morning...I go 500 on our 31 Tudor. The engine is rebuilt Babbitt with about 10,000 miles on it. This forces me to lube everything at 500 and oil as necessary. I think the lube work on 31 lube fittings is just as important as the oil change. I do run an air filter and an oil filter. The engine builder has me running Castrol HD Heavy Duty 30 weight detergent. I have the Snyder's Oil Filter which comes as part of a new valve cover and the filter is a Fram PH8A. There are many opinions on this subject depending on your location and weather...but this is how I have maintained our A for years...Have a Happy Model A Day...Ernie in Arizona
Old 08-31-2019, 11:50 AM   #8
Railcarmover
Railcarmover's Avatar
On an engine 'new' to me?..I change it after an hours run,then after the first good drive then go on an interval,500 or 1000 miles..most folks change the oil prior to selling a car,but that doesnt tell you what they did prior to sale..so flush it a few times,oil is cheap
Railcarmover is offline   Reply With Quote
Old 08-31-2019, 01:03 PM   #9
Cape Codder
Cape Codder's Avatar
Ernie: So now that you have 10,000 miles on your rebuilt are you about to drop the oil pan and check your mains and rods of clearances?
Cape Codder is offline   Reply With Quote
Old 08-31-2019, 01:13 PM   #10
rfitzpatrick
Once changed the oil filter on this Boeing 777, asked the Captain if he would 'pull-power' at the gate on departure while I leak-checked: "The Company Follows The BOOK, --- I Follow The BOOK".
Change my oil and lube every 500 miles-- per the Book
rfitzpatrick is offline   Reply With Quote
Old 08-31-2019, 01:53 PM   #11
Werner
Werner's Avatar
I change all 500 Miles, because this is the only way to take out dust and abrasion.
(Although I drive >2500 ml/year, although I use modern synthetic. 500 is enough. )
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 08-31-2019, 08:40 PM   #12
Synchro909
Synchro909's Avatar
I run an air and an oil filter. At least 1,000 miles between oil changes.
When on a long tour, I keep an eye on the speedo, temp and oil gauges. While the oil is fresh, temp on 180F, speed on 50 mph and pressure on 26 psi (I made a relief valve aiming at 25psi to the middle main bearing). Those figures don't change day after day until eventually, at the same speed and temp, the pressure starts to drop. I change by the time its down to about 23-4 psi. I figure that when that happens, the oil has run its race and should be replaced. I use the cheapest, nastiest oil available and using this method, the change comes around reliably at 3,500 miles. I've done 50,000 HARD miles on that motor and it's still going fine.
Life's journey is best undertaken slowly.
Old 09-02-2019, 10:58 AM   #13
Jim Brierley
I run full-flow oil filters on my B engines, no air filter, and I live on a dirt road. I run modern oil, 20w-50 and change once a year which is about 2500 miles. I've been doing this for 60 years, the cylinder walls show very little wear, same with the bearings. I used to change oil on my F-250 diesel every 4,000. One time I pulled our 5th wheel to Alaska and back to SoCal, and put over 6,000 miles on it. I sent a sample of that oil to a lab, the results said everything looks good, no need to change more often. My 2013 F-350 says to change every 7500, which I do.
Old 09-02-2019, 11:24 AM   #14
30 Closed Cab PU
IMO
Running an oil filter really changes oil change intervals. Originally with non detergent oil, the filth settled out, and if you look carefully in the instruction manual, part of every oil change included dropping the oil pan and cleaning it out. I do not remember seeing anything official, but suspect Ford garages also as part of normal maintenance periodically pulled the valve access cover and cleaned it out. So if you find a motor with lots of sludge, my belief is one of the reasons for the sludge is the motor was poorly maintained.
If using detergent oil/no oil filter, all the filth stays suspended in the oil, where it is constantly part of the lubrication of the rod/main bearings. This is one of the reasons I still change my oil every 500 miles, even running with a Hi Boy air filter/air balanced zenith carb (to repeat, no oil filter).
If running an oil filter the filth is removed that is suspended in the oil, allowing for longer oil change intervals.
Old 09-02-2019, 12:14 PM   #15
Ernie Vitucci
Good Morning Cape Codder...The engine is still very quiet...so I'll wait a bit longer on dropping the pan and checking the rods and mains. The fellow who built the engine says to leave it alone if it is quiet and maintained as I maintain it. I do use a little strainer when I change oil so that I can see if there is any metal coming out with the oil...the oil is coming out clean...I don't claim to be very bright, I just share what I do and what I have observed...Have a great Model A day. Ernie in Arizona
