01-03-2020, 11:43 AM | #1 |
1941 Merc Carb Kit wanted/needed
my dumb dirtyword cotton-picking booger-eating snot-sucking finger-licking 1941 Mercury 19A Carb is leaking and I cannot find a carb kit for it. the carb sez FORD "model 91-99" & 15/16. thanks. stay safe
01-03-2020, 12:07 PM | #2 |
Re: 1941 Merc Carb Kit wanted/needed
The model 94 carbs are all very similar. I would suggest CharlieNY here on the barn for a rebuild kit or repairs. There are others as well. Here is a thread with info.
https://www.fordbarn.com/forum/showthread.php?p=895023 The power valve fit is the main concern on all the model 94 units. A guy like Charlie can get the modern ones to fit and seal correctly. Last edited by rotorwrench; 01-04-2020 at 01:24 PM. Reason: correction thinking 94 put 48. my bad. |
01-03-2020, 12:12 PM | #3 |
You will find the kit for your '41 Merc at C&G (800/266-0470). ask for 59A-9590-HQ, V8, "94", $41.95. If your carb is beyond rebuilding with a kit, often the case with original or very old carbs, a replacement is also available at C&G as 59A-9510-N. From your colorful description, I suspect that you may wish to go there. Most old carbs have warped bodies and other problems that defy repair with a kit alone.
01-03-2020, 02:23 PM | #4 | |
He repairs all the problems that exists in any particular carb. When it comes back, it is better than new and that includes "new" reproductions. I'm speaking from experience as he has done two of mine and they ran perfectly right out of the box. Ken |
01-03-2020, 05:43 PM | #5 |
thanks to all..... more info than I could freaking find on my own.
thanks. stay safe |
01-03-2020, 05:49 PM | #6 |
01-03-2020, 06:24 PM | #7 |
grouch,
91-99 is the correct carb for your Merc. Give the carb a good look over to determine where the leak is coming from. Please keep me in mind if the kit doesn't do it. Since you are in Fla think about calling DAYTONA PARTS for a kit. 386 427 7108. Thanks, Charlie ny Last edited by Charlie ny; 01-03-2020 at 06:31 PM. Reason: spelling of for changed |
