11-02-2020, 03:26 PM | #1 |
ZDDP oil additive
I called C&G Ford Parts to purchase ZDDP for my Coupe's winter oil change.
They said it is no longer on the market. Any ideas/suggestions? |
11-02-2020, 03:35 PM | #2 |
Re: ZDDP oil additive
It's still "on the market". Order it from somewhere else. Ebay, Jegs, Summit, Amazon,
11-02-2020, 04:02 PM | #3 |
Use an oil with enough already in it?
11-02-2020, 04:52 PM | #4 |
I have been using Marvel Mystery's classic car oil. It has Zinc in it and formulated for antique cars. Right now on their site they are buy 2 get one free, so I stocked up heavily last week
https://shop.marvelmysteryoil.com/co...motor-oil-32oz |
11-02-2020, 08:29 PM | #5 |
With the low valve spring pressure the stock flatheads have, any currently available motor oil with a valid API rating has enough zinc. If you are still worried about the zinc content. any name brand oil with a "50" in the weight has more than enough zinc in it for even the highest valve spring pressures. I currently run Mobil 1 15-50 in the hemi in my race car with an Engle roller tappet cam that has dual springs with no problems for the last 25 years.
To make along story short, guys with stock flatheads don't need to worry about zinc as long as you use any commonly available API-rated oil. Just don't use non-detergent. |
11-02-2020, 08:52 PM | #6 |
11-02-2020, 09:38 PM | #7 |
Been using any regular oil for 25 years in mine. Whatever is on sale. No extra ZDDP needed.
11-03-2020, 01:17 AM | #8 |
11-03-2020, 12:48 PM | #9 |
Sometimes the xtra additive clashes with the original oils additive packaging and you end up with something less suited for the use
11-03-2020, 01:30 PM | #10 | |
I will repeat, any currently available oil with a valid automotive API rating is more than sufficient for a stock flathead just as it comes out of the bottle. |
11-03-2020, 01:44 PM | #11 |
2x what tubmans posted.
11-03-2020, 04:10 PM | #12 |
I am running a higher lift cam and Zephyr valve springs, so I feel more comfortable with more zinc than regular API oil. My solution: one quart of Valvoline TR1 racing oil for the zinc, three quarts of any good API oil for the detergent, and a pint of Marvel Mystery Oil because every flathead guru I have ever known says it works.
11-03-2020, 08:23 PM | #13 |
Thank you all.
11-03-2020, 08:40 PM | #14 |
Will not start any of my engines without adding bottle of zddp. Cheap insurance
11-04-2020, 09:05 AM | #15 |
I use 3 - 4 ounces of this Lucas product # 10063. Available at NAPA
11-04-2020, 09:25 AM | #16 |
I got ZDDP at O'Reillys and will service the coupe today.
11-04-2020, 01:39 PM | #17 |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-04-2020 at 03:07 PM. |
11-04-2020, 02:52 PM | #18 |
11-04-2020, 03:22 PM | #19 |
Using VR-1 for years
A man should do what he thinks best! "The Duke" |
11-04-2020, 03:27 PM | #20 |
Pete That is what I bought at O'Reillys. Thanks for the reply.
