Old 07-30-2017, 11:11 PM   #1
Sanddoc
Default Master cylinder
Hello
Just a quick question on the 54 model year.
where was the Mastery cylinder located?
Best
Sanddoc is offline   Reply With Quote
Old 07-30-2017, 11:24 PM   #2
Daves55Sedan
Default Re: Master cylinder
Well...on the 49-50-51 Ford it was mounted on the inside car frame rail under the driver side floorpan. You had to pull up the floormat and pop out a round floorplug to gain access to the filler cap.
So if your car has the clutch and brake pedals that go down into the floor like them, it is under the floor, but if the clutch and brake pedal arms go up under the dash, it is in the engine compartment mounted on the firewall above the steering column.
Daves55Sedan is offline   Reply With Quote
Old 07-31-2017, 01:29 AM   #3
Alaska Jim
Alaska Jim's Avatar
starting in '52 they were on the firewall under the hood, if I remember correctly.
Alaska Jim is offline   Reply With Quote
Old 07-31-2017, 07:50 AM   #4
Sanddoc
Thanks for the info..
I am looking at a 54 convertible, $2400. but want nothing to do with that old
under the floor braking system....
My 56 Packard, thanks to Mr. Nance was still using the floor\rail system Bendix
brakes... And without doing some major mod to the fire wall or removing the air
intake duct from the engine compartment there is no place for a modern MC .
Not sure I'm going to buy the 54, but wanted some heads up...
I have a 292 out of a 64 truck, with 3sp. But the car also has floor rust...
I keep saying I'm getting too old to start new projects...
We had a 51 Ford custom when I was a kid, I loved that car, my brother got it when
the parents bought a 62 Ford wagon, which is one of the cars I'm working on now and
rust out passenger side floor pans are keeping it in the driveway..
Ok, thanks again guys.
Best
Old 07-31-2017, 07:57 PM   #5
5851a
Originally Posted by alaska jim View Post
starting in '52 they were on the firewall under the hood, if i remember correctly.
x 2
5851a is offline   Reply With Quote
Old 07-31-2017, 08:49 PM   #6
paul2748
paul2748's Avatar
Yup - left side of the firewall, up near the cowl.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-01-2017, 01:12 AM   #7
JeffB2
JeffB2's Avatar
And for an easy and cheap update. https://www.youtube.com/watch?v=wXfXKlj2D1I
JeffB2 is offline   Reply With Quote
Old 08-01-2017, 05:18 PM   #8
mobileparts
I have them ++ Brand New ++ U.S.A. Made, if you would like or need.
They fit 1952 - 1956 Ford, Mercury, and 1952 - 1955 Lincolns, no Trucks.
Brand new -- no core required......
Call me -- Craig -- 516 - 485 - 1935.... New York....
mobileparts is offline   Reply With Quote
Old 08-02-2017, 08:55 AM   #9
Ole Don
Ole Don's Avatar
I did not watch all three videos to see if this was covered. When installing a newer master cylinder with only two bolts, be sure to run two bolts through the other two holes, as they hold on an important bracket on the inside that is very hard to see.
Ole Don is offline   Reply With Quote
Old 08-02-2017, 03:15 PM   #10
JeffB2
JeffB2's Avatar
It was covered
Thread Tools
Display Modes
